Old 06-24-2007   #1
blowing smoke
my bike is blowing white smoke every time i take off some one help
loveandevil666 is offline   Reply With Quote
Old 06-24-2007   #2
Re: blowing smoke
Mixed in too much oil?
silver93t is offline   Reply With Quote
Old 06-24-2007   #3
Re: blowing smoke
yeah,are you still running 25:1? try 40:1
unfamous13 is offline   Reply With Quote
Old 06-24-2007   #4
Re: blowing smoke
It's normal for you bike to blow smoke. If there is too much smoke, try leaning out the air/fuel mixture, or increase your fuel/oil mixture to 50:1
gabrielb25 is offline   Reply With Quote
Old 06-24-2007   #5
Re: blowing smoke
increasing? you mean decreasing ofcourse correct? and white smoke is not air to fuel mixture,white smoke in these applications means oil is burning,aka too much oil in the mix.I would highly reccomend going DOWN on the oil to a 40:1 mixture
Old 06-24-2007   #6
Re: blowing smoke
Correct me if I'm wrong, but isn't some smoke normal, even with a correct mix, on a 2 cycle? I tried different oil myself that is smokeless, the other oil I used was quite smokey at full throttle and I used the mixer that came with the bike.
ibanender is offline   Reply With Quote
Old 06-24-2007   #7
Re: blowing smoke
smoke is normal but white smoke means burning oil.when i used to run 32:1 i had white smoke,but when i went to 40:1 i had no more white smoke,maybe a tiny cloud every once in a while
Old 06-25-2007   #8
Re: blowing smoke
It's a 2 cycle what do you expect.
kartracer11 is offline   Reply With Quote
Old 06-25-2007   #9
Re: blowing smoke
sorry for dble post
Old 06-25-2007   #10
Re: blowing smoke
White Smoke= Burning oil=too much oil in mix
Old 06-25-2007   #11
Re: blowing smoke
mine smokes with 40;1 mix,nothing like it did with 25;1,my plug is a medium brown
swanni06 is offline   Reply With Quote
Old 06-25-2007   #12
Re: blowing smoke
I guess i must read elsewhere
Old 06-25-2007   #13
Re: blowing smoke
dude lol why are you writing this in every post?
Old 06-25-2007   #14
Re: blowing smoke
Ya, my plug was just right coming out and mine smoked like hell. I changed oils to a smokeless and now it doesn't smoke, imagine that.
Old 06-25-2007   #15
Excommunicated PBP Staff
Re: blowing smoke
Castor oil=no burn=no smoke= 32:1 ratio
Synthetic oil= burns=smoke=50:1 ratio
Sorry for repeating but everyone gives the same ratios (40-50:1) but they never specify which oil that ratio is for.
For semi-synthetic oil, like Castrol 747, you should run a 40:1, and it will barely smoke and give that castor protection i love.
minimotoracer311 is offline   Reply With Quote
Old 06-26-2007   #16
Re: blowing smoke
dont use castor
If for some stupid reason you do, you should mix marvel mystery oil (However it's spelled) in with some fuel and run that through the engine and carb, otherwise you will have one gummed up engine
Old 06-26-2007   #17
Re: blowing smoke
is amsol synthetic good to use? i am using castrol 2-stroke oil in mine, just the regular kind
Old 06-26-2007   #18
Re: blowing smoke
Its not your oil
the samething is happening to me now clean out your silencer stuff (not sure what its called the white matterial inside the shroud). i looked at mine today and its full of oil and when ever it heats up it causes more white smoke. i ran my bike without the muffler and there was barely any smoke coming out
.-matt-. is offline   Reply With Quote
Old 06-26-2007   #19
Re: blowing smoke
dont use castor
hmm sorry,newer had/seen/this/heard this ever happen.
Old 06-26-2007   #20
Re: blowing smoke
The castor from Castor beans will separate from the fuel if it sites to long, and if it gets cool out.
Thats why you never use castor oil when it's cool outdoors.
Also there is often fibers from the bean in the fuel mixture that will clog carburetor jets.
Running the MM oil mixture through eliminates possible gumming
More protection, More carbon buildup, Higher maintenance.
Next time don't post misinformation.
Page generated in 0.34193 seconds with 75 queries
