View Poll Results: Boost Bottles
Good 145 71.43%
Bad 61 30.05%
Multiple Choice Poll. Voters: 203. You may not vote on this poll
Old 09-12-2007   #181
Question boost bottle
loL do boost bottles actually work from ebay?
http://cgi.ebay.com/39cc-40cc-gas-sc...QQcmdZViewItem
liqourish is offline   Reply With Quote
Old 09-12-2007   #182
nissandude's Avatar
Re: boost bottle
they dont do anything but give you better gas milage thiers hundred of posts on it use the search
nissandude is offline   Reply With Quote
Old 09-25-2007   #183
Re: boost bottle ?
do boost bottles work on 4 stroke pb's and how do you install them?
wolvesracing is offline   Reply With Quote
Old 09-27-2007   #184
puppetmaster's Avatar
Re: boost bottle ?
theres somethings you need to know about boost bottles, ok, first off, you don't drill your case. its actually your intake block. second of all, you have to answer this for me. if boost bottles don't work, then like they the other guy said, why do they have they for sleds, also, they make them for 4 wheelers, like the banshee and most 2 strokes, you should research the boost bottle a bit more, and you will find out that they do work. ONLY if you make them correctly.
theres a formula to use to make them the right way. and to figure out the correct volume for the bottle.
1cu. in. = 16.3871cc
divide your cc by 16.3871 and you will get the correct cc to use for your motor.
in a nut shell here are some done for you. these are not my formulas, im not taking credit for these, but just posting them for those to read.
49cc = 2.99cu.in.
43cc = 2.62cu.in.
47cc = 2.86cu.in.
39cc = 2.37cu.in.
the volume of the boost bottle must be exact to your size. if not it will not work properly.
good luck.
puppetmaster is offline   Reply With Quote
Old 09-28-2007   #185
stuch's Avatar
Re: boost bottle ?
bottom line they do work. but they don't create power the thing they do is give you better gas mileage. they create back pressure inside the bottle and send that pressure in to the carb manifold and create a mist from the gas going through the manifold bodyinto the crankcase into the motor. and give you better fuel burn. inturn better fuel mileage. and maybe just maybe a little more lowend. but they don't do anything for mid or topend power. and the down fall to them is they could leak in a number of places. so if you are thinging of running one make sure you bench the bottle to see if it hold a charge of pressure.
stuch is offline   Reply With Quote
Old 09-28-2007   #186
Council Member
sr20hardbody's Avatar
Re: boost bottle ?
so if i correctly measure the volume will this work on my banshee?
Old 09-28-2007   #187
stuch's Avatar
Re: boost bottle ?
the gain you're going to get from one is like 1-3% nothing you'll see in the seat of you're pants. not only that the banshee mainfold is rubber more of a chance for leaks when you mount the 1/4 inch nipple.
Old 09-28-2007   #188
Council Member
Re: boost bottle ?
i heard they only work for piston port motors is that true?
Old 09-28-2007   #189
stuch's Avatar
Re: boost bottle ?
i know this they came stock on a rc motor on a .21 size motor in 2003-2004 models. they were used to get longer run times on a tank of gas. so lets say this in a [A] main event you race you off road car for 35 min's and on average you would pit for gas every 5 min's thats 6 pit stops if you could get that to 5 pit stops thats a big advantage over the next guy that has to pit 6 times.
Old 09-28-2007   #190
stuch's Avatar
Re: boost bottle ?
i just bought one a min ago for my rc boat with a rc230 22.5 cc go-ped motor.
Old 10-08-2007   #191
Thumbs up Re: Boost Bottles
Originally Posted by Mblough View Post
i voted bad. bad because they are never made correctly. people dont calculate the volume they just slap some ghetto azz crap on thier. ive seen m&m bottles, sunny D bottle, a perfume bottle, all kinds of crap. all this just has a displacement into the several hundreds of cc's not 43-49 like they are suposed to. even when they get that part right they never add the displacement of the tubing used as well. like ive seen a couple boost tube is the right size then tubing is ran to put it at the back of the bike to look like a big bike brake resevior or something. once again all this tubing adds to mroe displacemet then the boost box is suposed to.
With all that said DO NOT BUY EBAY BOOST BOTTLES!!! They are made by amatuers and shade tree knuckle heads. 15-20 bucks? Give me 5 and ill kick you in the junk. then when you get up at least youll still have some money left.
Hello, Actually you are wrong. We have a team of tech's here which make our boost bottles exactly to your engine size. Kick me in the junk? nah, our boost bottles will give you the boost you crave. visit www.bis-racing.com for additional info.
BOOST INDUCTION SYSTEMS is offline   Reply With Quote
Old 10-08-2007   #192
Re: Boost Bottles, Do they work?
Originally Posted by PurePerformance View Post
Ok, I have yet to test this item out. So I need some input from your guys.
1- Boost Bottles, do they work? I totally understand the workings of this performance MOD but would like some more info.
2- Has anyone made one for them self or is everyone just buying them from suppliers and FleaBay?
3- This MOD looks very cheap and fast so why is everyone not using them?
4- I would like to hear some facts as far as MPH Ratings etc...
Well thanks in advance fellas .
RIDE PURE
Hello, MPH gains can be extreme depending on whom is explaining. It all depend on your gas and weight of the rider during the installation. If you buy our custom made boost kits, there are no VAC leaks (in between the manifold and the bottle fitting) These leaks are vac leaks that most operators report as a downgrade to their pocket bikes.. The whole time the bottle is doing nothing and the engine is sucking air around the fitting. Be sure to get a kit that is PROFESSIONALY installed before giving boost bottles a bad wrap.
Thanks, Jim
www.bis-racing.com
Old 10-08-2007   #193
Wink Re: Boost bottle
Originally Posted by bmarley5780 View Post
Lowe's - saw a little bottle of-----> wd-40 -----> 2 oz.
-----> beautane(sp?)-----> 1.5 oz.
1.5oz curently on my bike, have yet to take off/on and see if it does anything.....
This is because you guys out there are running BS on your engine thinking that all you need is displacement. It must be measured carefully. Please, do not put this junk on your bike and downgrade it.
visit www.bis-racing.com for more info.
Thanks, Jim (owner)
Old 10-08-2007   #194
Originally Posted by bigsugar500lbs View Post
PVC + GASOLINE = BAD
have fun with your fuel system after a while with melted pvc in it.
PVC? Don't know where your bottle came from.
*correction* Our boost bottles are made from polymer with a aluminum lined tank. Where the heck do these "rumours" come from?
Your fuel tank itself is made from PVC! Does it melt all over your system the same as a plastic gas can, etc... You dont think we think of this stuff?
Thanks, Jim
www.bis-racing.com
Old 10-08-2007   #195
Re: Boost bottle
where can i buy a boost bottle...how much...???is it really worth it
tnj06 is offline   Reply With Quote
Old 10-09-2007   #196
Re: Boost bottle
Hell yeah it is worth it. Without a boost bottle, you are forced to run a double rich mix. This causes hesitation, bogging, etc... it also slows your acceleration. i (we) have been in the pocket bike business since 2003. You can get your boost bottle on our website: www.bis-racing.com
Trust me, you will love the results. I guarantee it. Or I will buy it back from you.
Thanks, Jim (Owner) www.bis-racing.com
Old 10-12-2007   #197
team gorilla racing TGR's Avatar
Re: boost bottle ?
i have a ada juice box on my x1 it smooth out the top end gave better throttle response and better gas mileage this on piston portmotor though
team gorilla racing TGR is offline   Reply With Quote
Old 10-14-2007   #198
Re: boost bottle ?
They don't store air,gas,increase mileage.All they do is change the sound wave your intake is making,it only help with throttle response and engine flutter.Stiffer reeds will do the same thing or the juice box is the best bet.most boost kits are not made right.
jg90gt is offline   Reply With Quote
Old 10-29-2007   #199
Re: boost bottle ?
It's function is to absorb & release pressure pulses within the intake vein, assisting engine breathing. Now an explanation of exactly what goes on involves a lot of physics and a good understanding of fluid dynamics & pressure zones, but can be explained rather easily. During the intake stroke, air is sucked through the intake manifold and into the port at a considerable velocity. Because of this velocity, the air is said to have relative inertia. Now, when the intake valve closes, the kinetically charged air suddenly has nowhere to go, creating a high-pressure area. Naturally, the air wants to release its pressure in the easiest way possible, so it tries to shoot back out the way it came, creating a pressure wave in the opposite direction we want it. Then no sooner dose the wave begin to travel, the intake valve suddenly opens again leaving the motor to try and pull the pressure wave back in again. This dramatically effects low RPM, wastes energy and kills low-end performance. Now the same engine, but with a BOOST BOTTLE. Air goes whistling down the manifold until the intake valve closes. The air, still all charged up with energy tries to escape back up the manifold but is met with a small port that has a residual vacuum. This vacuum being caused by the previous suction of the intake stroke, sucks most of the pulse inside the Boost Bottle, storing much of the pulse’s energy. The intake valve then suddenly opens, creating a low-pressure area outside of the Boost Bottle. The gasses then shoot out of the Boost Bottle, directly into the intake system as a pressure pulse, instead of having to be pulled in by the piston. More air is then also pulled in from the manifold to completely fill the cylinder… Thus giving you an additional boost of power
Old 10-29-2007   #200
Re: boost bottle ?
my hands hurt
Boost bottle materials Supa Dexta Air Cooled Pocketbikes 6 08-15-2005 09:23 PM
Home made boost bottle review!!! u sucker just got served 2Stroke Midbikes 22 07-16-2005 02:14 PM
boost bottle test smn1 2Stroke Midbikes 10 07-06-2005 01:30 AM
boost pressure gauge for a boost bottle? u sucker just got served 2Stroke Midbikes 22 06-25-2005 12:17 PM
Page generated in 0.39159 seconds with 78 queries
