View Poll Results: Boost Bottles
Good 145 71.43%
Bad 61 30.05%
Multiple Choice Poll. Voters: 203. You may not vote on this poll
Old 11-13-2004   #41
marctronixx's Avatar
yeah , just look at the similar threads below...
marctronixx is offline   Reply With Quote
Old 11-13-2004   #42
x5pocketbike's Avatar
i have one on my x5 and all it did was screw with its idling and running capabilities. but i can see fumes going to the engine through the tube, but i'm going riding tomorrow and going to try to tune it, so i'll reply then.
x5pocketbike is offline   Reply With Quote
Old 11-13-2004   #43
Hotscoots's Avatar
Originally Posted by racinjason
Please Post Your Experiences With The Boost Bottle Here. I Am Not Sure If I Beleave They Work.
I Have A Honda Hrc Gp Bike And If They Worked I Think Honda Work Have Them On It Since The Bike Is Around $30,000 And They Would Do Anything For An Advantage.
Your $30k Honda most likely has reed induction . In which case, a boost bottle would be useless .
The boost bottle provides a storage tank for pre-atomized air/fuel mixture. When the piston moves up towards TDC , the boost bottle assisits in filling the cylinder with pre-atomized air/fuel mixture for a fraction of a second until the carb venturi gets enough velocity to fully atomize the fuel.
The boost bottle provies a "BOOST" supercharged effect to each cycle. The advantage is that it brings up the torque and horsepower in the lower RPM range.
Hotscoots is offline   Reply With Quote
Old 12-12-2004   #44
PurePerformance's Avatar
Question Boost Bottles, Do they work?
Ok, I have yet to test this item out. So I need some input from your guys.
1- Boost Bottles, do they work? I totally understand the workings of this performance MOD but would like some more info.
2- Has anyone made one for them self or is everyone just buying them from suppliers and FleaBay?
3- This MOD looks very cheap and fast so why is everyone not using them?
4- I would like to hear some facts as far as MPH Ratings etc...
Well thanks in advance fellas .
RIDE PURE
PurePerformance is offline   Reply With Quote
Old 12-12-2004   #45
blah's Avatar
Old 12-12-2004   #46
You know what if I knew that this was a big thing on PBP I would have never posted thisn question. Wow Ok. Thanks for the thread link I will read up and see how these things work and if I would to place one on my bike.
Thanks Blah
Ride Pure
Old 12-12-2004   #47
blah's Avatar
No worries mate, looks like the search link died though?
Thanks Blah
Ride Pure
Old 01-08-2005   #48
fastcag's Avatar
boost bottle ??
anybody have any success with these on the cag's?? i was thinking about making one of these to try and give me some low end kick..
fastcag is offline   Reply With Quote
Old 01-08-2005   #49
badazztoyz.com's Avatar
ive never tried one but from the way i think they work i would think you would kind of kill your topend but like i said i havent tried them so yeah mmk
Old 01-08-2005   #50
fastcag's Avatar
Question boost
it seems the key is to get the boost bottle small enough to match the 37-40cc cylinder on the stock cags.. a small 2oz wd40 bottle holds 122cc's which is way to big. any ideas on what to use for a bottle???
Old 01-08-2005   #51
fastcag's Avatar
co2 bottle
i wonder if a small empty co2 bottle, like for bb guns, would be good??
Old 01-08-2005   #52
Pred6380's Avatar
Hmm, that actually sounds like a good idea if it would work
Pred6380 is offline   Reply With Quote
Old 01-08-2005   #53
fastcag's Avatar
well if anybody has the dimensions (length & diameter) we can get a cc volume.... i wish i still had my pellet gun...
Old 01-09-2005   #54
Wicked1's Avatar
You can't just grab a bottle that looks like it'll work and expect it to... if that was the case you could just get on ebay and get one for a lot more than it's worth.... and they are even painted blue with NOS stickers on them to ensure you'll go really fast.
OK.. all B.S. aside...
Here's a good post on how to make the bottle and he tells the math formulas for the correct bottle and hose sizes. You'll just need to use 40.2cc for the engine displacement whenever you do the math.
I'm still not sure if this should be done to a reed induced engine or if any gain would even be noticed... not to mention adding in a little extra bottom end could harm the top end's output.
Wicked1 is offline   Reply With Quote
Old 01-09-2005   #55
Question
where do you connect the boost bottle?
BILISRACING is offline   Reply With Quote
Old 01-09-2005   #56
tblumer's Avatar
I would think the boost bottle theory wouldnt work with the reed inducted motors (although they do use them on dirtbikes and atv's successfully) only for the fact that the reeds should, in theory, close tight and prevent any backflow of fresh charge to head back out of the crankcase and thru the carb. Or are they only useful at low rpms where the crankcase pressure may not be high enough to seat the reeds tightly?
Old 01-09-2005   #57
scrambledeg's Avatar
Just to let u know I know the person that sells the boost bottles that a blue with the NOS stickers on Ebay. And they have been calculated and they do work. So b4 u go and think ur the guru of boost bottles, y dont u go and do some research first b4 down playing something u know nothing about. Besides those boost bottles are being sold to cateye,x1,x2,x7 etc.... bikes that arent reed valve motors.
scrambledeg is offline   Reply With Quote
Old 01-09-2005   #58
Wicked1's Avatar
****... talk about a crybaby... have you noticed that you're in the CAG forum and not the cateye,x1,x2,x7 etc.. forum?
I know quite well these work on that engine cuz they are sized for them,they are not sized for a cag. I also know quite well that I've seen the add on ebay several times over where it is claimed they work for 47/49cc engines....Hmm.. what are the cag engines considered to be? could it be... 47cc?
Edit: Here's the boost bottles on ebay with the NOS stickers...
7126672302 ... claims a 3-5 mph top speed increase with a radar confirmed 7 mph increase and claims compatibility with 47/49cc engines Ya ... Right
7126376258 this one claims a 2-3 mph top speed gain and compatibility for the 47/49cc engines... Again.. No Comment
7125659001 this guy's at least honest and only claims to be compatible with the 43/49 cc X sesries bikes engines but has to throw in a Walbro 603 carb to ensure the customer sees a difference... Not bad for $85+ $9.95 shipping all for a $5 pvc bottle and a $39 carb.
Old 01-09-2005   #59
fastcag's Avatar
boost
haha yeah i was gonna try a 1" x 3" copper pipe (2.44 cu. inch or ~40cc volume) or maybe one of those rc car boost bottles ebay item # 5948320162 that look like that size.
Old 02-01-2005   #60
dush's Avatar
nope i aint had no success
dush is offline   Reply With Quote
Boost bottle materials Supa Dexta Air Cooled Pocketbikes 6 08-15-2005 09:23 PM
Home made boost bottle review!!! u sucker just got served 2Stroke Midbikes 22 07-16-2005 02:14 PM
boost bottle test smn1 2Stroke Midbikes 10 07-06-2005 01:30 AM
boost pressure gauge for a boost bottle? u sucker just got served 2Stroke Midbikes 22 06-25-2005 12:17 PM
Page generated in 0.37731 seconds with 78 queries
