Originally Posted by supra95 What is this thing? it baisically melted on the other side becasue the exhaust got to hot...thats my guess. can i replace it?? if so how can i do this. also where can i get this new part?? Thanks alot guys http://home.comcast.net/~johnpark07/ff.jpg |
The thing you are referring to is a fuel filter. You can buy one at any motorcycle shop for less than $2.00. Turn the gas off, squeeze the clamps with pliers to loosen them, slide them up the hose, out of the way. Pull the hose off the filter and replace. Try routing your fuel line so that the new filter does not come in contact with the exhaust, otherwise it may melt all the way through and set you on fire. (Fire is bad).
Hunter
