Alright, I am really confused about this AC knock off of the Blata Origami B1. I purchased a 68 tooth sprocket for my friends AC
C1 because it was so slow off of the line and my thought was to get it at the same gearing as my 2 cags (6/68). When I got the back wheel off I discovered that this thing is NOT designed anything like my two half fairing cags. There are three gears and not two! There is a pinion gear that has 7 teeth which connects to a dual sprocket (each gear has 28 teeth) and then there is a rear sprocket which has 52 teeth. There are two chains involved in this set up. One chain connects the pinion gear (7 tooth) to the dual sprocket (28 tooth) and the other chain connects the other side of the dual sprocket (28 tooth) to the rear sprocket (52 tooth). There is no way that this 68 tooth sprocket will work unless I get the right size chain. The one currently on there is way too short.
I am going to try to organize my questions.
1. Are all Blata B1 Origami and Chinese knock offs of this bike designed in this same way where there are 3 sets of gears?
2. What is the gear ratio equivalent of a 6/68 half fairing cag for an AC
C1 or Hydra? How do I do the math on three sets of gears?
3. How do I adjust the chain tension of the first chain aside from removing a link? It is extremely loose..
4. Can I buy a new middle dual sprocket? The teeth are badly worn on the side of the dual sprocket that drives the rear sprocket (my friend rode it too long with the chain loose). Are there different gear sizes available for this part?
5. What is the best way to change the size of the chain? What tools do I need and who has them
for sale?
6. If the AC C1/Hydra is slow off of the line compared to a 6/68 HF cag, what is the recommended gearing for this bike? How can I make it accelerate faster? Does this bike accelerate faster with a bigger sprocket or a smaller sprocket if the default is 52 teeth? (I got confused when I read through the replies on this post. One person said to use a smaller sprocket and on person said to use a bigger one.)
Thanks to anyone who can help me figure all of this out. I have this friends bike torn apart in my garage and he is counting on me to get it running right for him.
