Old 02-06-2009   #1
Fezikk's Avatar
Cag issues, all around
okay i got a FUBAR cag today.... and got it started somewhat... i need quite a few things, like for one a complete exhaust pipe... the pervious owner took the exhaust pipe and broke the muffler off of it.. to make it sound FRIGGING ANNOYING>!... but i replaced the clutch on it... and when i go to start it, it is SUPER over revving.... so i tuned it to where it is kinda calmed down... and when i go to give it gas it has a Delay reaction to get gas to the engine and when i Disengage the throttle it takes a minute to react... how do i change the reaction time on it?
Fezikk is offline   Reply With Quote
Old 02-06-2009   #2
PBP staff
Nirvash#000's Avatar
Re: Cag issues, all around
did you clean the carb real good and you might have an air leak at the carb or manifold and is the throttle lubed because if it isnt its probably getting stuck
and whats a FUBAR cag?
Nirvash#000 is offline   Reply With Quote
Old 02-06-2009   #3
Fezikk's Avatar
ill check those, the gasket on the carb is half on, so ill fix that, and i didint lube nothing on it where should i lube it..... and Fubar Cag is
***ed up beyond all recognition
Old 02-06-2009   #4
Hooligan
SpyGuy's Avatar
FUBAR = Eff'd Up Beyond All Recognition. Don't they teach you youngsters anything these days ...?
as Nirvash pointed out, your "delay-reaction" throttle may simply be a case of the throttle cable binding or sticking in the cable cover. Squirt some WD-40 down inside the cable cover.
What color's your spark plug? Did you clean the plug before you fired it up? If not, do it, get the bike running for a few moments, then shut it off and pull the plug again.
Old 02-06-2009   #5
PBP staff
honestly thats the first time ive see that word i feel stupid ?.?
Old 02-06-2009   #6
Fezikk's Avatar
i didnt check the spark plug.
the gasket for the carb is only half on though, so ill check em out
and Fubar is a military term, in alot of war movies like
Saving private ryan,
but he says it stands for something else...
Old 02-06-2009   #7
Fezikk's Avatar
cool, got it all situated, lubed the throttle cable, fixed the carb gasket. fixed the needle pin to the 5th notch... so all i need to do it buy a
Exhuast Pipe
Chain Guard
windsheild
then im all set with another bike,
well after a paint job...
Old 02-07-2009   #8
PBP staff
so it runs and idles fine now?sorry for the short message.my hand is killin me im tired of this carpal tunnel
Old 02-07-2009   #9
javy_trkstr's Avatar
Yikes sorry bout the carpal tunnel nirvash, but if you don't mind gore or war I definitely recomend Saving Private Ryan, one of the best war movies out there.. nd thanx for the wd40 trick on my throttle cable spyguy, don't know why I never thought of that, gotta lov a different prospective now and again,
cheers
javy_trkstr is offline   Reply With Quote
Page generated in 0.31056 seconds with 41 queries
