alright, a freind of mine has a full fairing cag, never really had any problems. until recently, it was not starting at all. so first i asked what mixture and how old the gas was, well it was crappy oil (weedwacker oil) and it was quite old, so i thought the carb was gummed up. so, i cleaned everything in the carb out, put it back together, put fresh oil and gas in (redline 2 stroke perf oil) and tried to fire her up, no go. checked for spark, it had a strong blue spark, with 2 different plugs. so i gave up for the night.
*oddly enough there were several pops(backfires) from the exhaust* not sure what they where about.
next day, equiped with quickstart, we try again.a little quickstart in the carb and we try, no go. i notice a fair amount smoke coming out of the head and exhaust gasket/header. now, im not sure if that was just the quickstart being burnt off or not. while im down there i notice there is a small gap, 3mm or so bewtween the head and the gasket. now it gets me thinking, hes had this exhaust for quite a while. and could it of fried the piston???
*this was a new exhaust, not from factory, hence the reason it was NOT installed correctly*
recap
-bike has good compression
-is not a fuel delivery problem, it didnt even start with fuel directly down in the head.
-spark is strong
so, could it be time for a rebuild?. like i said before the bike backfired several times, and i told you about the gap bewtweent the head and gasket. could this of lead to the piston being fried?
sorry for the long post
