Old 09-06-2004   #1
Can anyone help me out please
I just bought a Cag from a friend of mine and I am having a few problems. It seems to die very often unless I stay on the gas a little. Is there a way to adjust this? I have also noticed that the chain is beginning to make a lot of noise, it seems to be getting louder. I am very new to this scene and any help would be greatly appreciated. If there are any tips you may have to share please do so. Thanks in advance.
Steve
dblr1 is offline   Reply With Quote
Old 09-06-2004   #2
Steve
You just need to adjust the idle a bit. On the left hand side of the bike there is a screw on the carb. Just turn it clockwise until the bike idles without helping out with the throttle. The chain is noisy because it needs to be lubed , go to a bike shop (or even Walmart) and get some chain lube. It's also possible that it needs to be tightened a bit.
KECHME is offline   Reply With Quote
Old 09-06-2004   #3
thanks man I appreciate it. I have some Bel Ray chain lube left over from my R1 so I will use it. How do I adjust the chain and how much slack should I have on it.
Thanks,
Steve
Old 09-06-2004   #4
macias777's Avatar
Thanks,
Steve
Check you chain tensioner guide and make sure the engine lined up evenly with the back sproket and lube it up!
How to tune your carburetor
Due to the increased power and hence increased vibration that results from installing the larger carburetor, you will most likely need to adjust the jets much more often than the jet for the stock carb. If you find your top-end RPM's have fallen off a bit, or if you experience lagging or surging, it is probably time to re-adjust the carb jets. To ensure max performance and engine life, follow this procedure:
1) Locate the low and high RPM jets on the side of the carb - they are usually marked with a L and a H. Turn both jets completely CLOCKWISE ( to the fully closed position).
2) Rotate the Low jet counter-clockwise to 1 and 1/2 turns open.
3) Rotate the High jet counter-clockwise to approx 1 turn open.
Note for the RC/ HE / SK carburetor (Walbro WT-603, or WT-668): set the low jet and high jet at 1 1/4 turns out.
4) Now, start the engine. You may need to turn the Low jet slightly one way or the other for the engine to start.
5) Adjust the Low jet as desired until the idle is where you like it. Turning clockwise ("CLOSING" THE JET) will produce a higher idle, and counterclockwise ("OPENING" THE JET) will produce a lower idle (and eventually flood and the engine will kill, if you turn it too far).
6) Lift the rear tire off the ground and pull the throttle lever to full blast. Adjust the High jet until you get maximum RPMs. Note: this will probably be REALLY LOUD. Listen for the highest-pitched whine to tell you where max RPMs are hit.
AFTER YOU FIND THE MAX RPM SETTING, TURN THE HIGH JET COUNTER-CLOCKWISE ("OPEN" THE JET) APPROX 1/16TH OF A TURN TO ENSURE YOU HAVE SUFFICIENT GAS/OIL MIX TO COOL THE ENGINE PROPERLY.
Note: The above are just general guidelines. You may need to adjust both the H and L screws once you begin riding, depending on rider weight, altitude, humidity, etc. The trick is to find settings that work well for you, and stick with them.
Here is some helpful information regarding common carburetor tuning problems:
If your e
ngine stutters at full throttle and cannot reach full RPMs:
The high jet is too far open. Close the jet by turning it clockwise slightly, and then ride-test. If no improvement, repeat until desired results are achieved. Once you have found a workable setting, open the jet approx 1/16 of a turn to ensure sufficient fuel/air mix.
If your engine bogs out when transitioning from low speed:
The high jet is too far closed. Open the jet by turning it counterclockwise until you are at least 1 1/2 turns open, and then gradually close the jet until performance is as desired. Poor engine compression, blocked exhausts, and very heavy engine loading can all also cause bogging.
If your engine idles very fast and kills if you attempt to slow the idle:
You may have an air leak in your intake. An easy way to check for leaks is to spray the intake manifold and area surrounding it with WD-40. If the idle changes after you spray the WD-40, there is an air leak. Common areas for leaks are between the manifold and the cylinder, and between the carb and the intake manifold. Inspect the manifold, carb gasket, and intake gasket for cracks or other signs of damage, and replace if necessary.
If your engine idles but then slowly kills:
Your low jet is too far open. Close the low jet by turning it clockwise until a stable idle is achieved.
Theres this info and much more at http://www.davesmotors.com/goped-faq-high.htm
macias777 is offline   Reply With Quote
Old 09-06-2004   #5
except that cags dont have high and low jets. i thought we only had one jet and an idle screw. so how do you do that DDM?
cjmatt is offline   Reply With Quote
Old 12-31-2004   #6
ok first of all
trevorjames is offline   Reply With Quote
Old 12-31-2004   #7
Pyrate's Avatar
Yet another ridiculous post by TJ! No wonder you have 3 warnings.
Great post Mac, do you have something similar for the stock cag carb?
Pyrate is offline   Reply With Quote
Old 12-31-2004   #8
You read my mind! trevorjames go away or grow up......
xedup is offline   Reply With Quote
Old 01-01-2005   #9
snowboardgeek1's Avatar
The writeup is for walbro carbs.
Old 01-01-2005   #10
REALLY Nice write up Macias...and trevor, man you should be banned, you have the weirdest, stupidest, and lamest remarks I have EVER read...good thing hes temporarily banned.....
John
Old 01-10-2005   #11
who owns an r1 and doesnt know how to tune a carb?!?!?!
wreckless_driver13 is offline   Reply With Quote
Page generated in 0.26979 seconds with 47 queries
