not sure why this old thread got brought up again...? lol a simular thread about pinion gears was made a few days ago with some helpful hints.
FOUND BY CLICKING HERE!
Originally Posted by honda_racer92 When they put it together from the factory they used some heavy duty locktite. Mine wouldn't even come off even with heat! So I got ****ed off and took a really big pair of pliers and wrenched as hard as I could, guess what it came right off weird. Of course I ruined the 6 tooth but it didn't matter because I was going to replace it any way with a 7. Then I bought another stock clutch bell with a 6 tooth sprocket in case I wanted that size later in life. Now I have what ever I need!
Hope this helps!!!! |
the heavy duty locktite you refer to is the white epoxy bond. pliers onto a 6t WILL damage the teeth of the pinion gear! if you used the gator grips I mentioned in the other post about removing pinion gears, this would have not happened!!!
Originally Posted by r1replica To ewerybody; I had my pinion problem to but the prob. was that the pinion was welded on the inside of the clutch drum. Yes it was punktured twice with MIG welder! I have had a hard time grinding that two little welds off. Howewer there was no loctite on the thread of a pinion. Hope this helps you guys. |
yes a few stock clutch bells do come welded at times. I came through a few "yomer" made cags that had welded clutch bells that I sold before. if the pinion needed to be changed, you would either have to buy another clutch bell housing and pinion or grind down the spot welds like you've mentioned.
