Old 06-22-2005   #1
merctech's Avatar
Carb problem
I let a buddy port my carb because he said he new what he was doing. He races dirt bikes. I thought Id give him a chance , but when I got my carb back the port is very large I put the slide in and looked through with a flash light on the other side and can see 3 slices around the slide. Is the carb junk now? Ive done some searching and come to the conclusion it will idle very high. Is there something I can do to save it? Please help.
merctech is offline   Reply With Quote
Old 06-22-2005   #2
Vbfinest's Avatar
you might be able to still set down
Vbfinest is offline   Reply With Quote
Old 06-22-2005   #3
Eddied118's Avatar
Talking
Maybe some epoxy or something like that to the sides of the slide to cover it up.. but i dont know lol
Eddied118 is offline   Reply With Quote
Old 06-22-2005   #4
hayabusa's Avatar
have you tried installing it and running the bike yet? how big did your friend go on the porting? can you post pictures of it by any chance with the slider down so we can see how much gap it has?
hayabusa is offline   Reply With Quote
Old 06-23-2005   #5
merctech's Avatar
No not yet I will sometime today . My camera is broke so no pictures sorry. With the slider down I can see aprox. 1 to 2 mm gap on the sides and maybe a little more on the bottom. I have a dremel kit and it has one of the sanding drums which I measured to be about 14 to 15 mm diameter it slides in easily in the front side and just barely in the back. It looks like he somewhat tapered it out. I know that its rough measurements but its the only thing I have thats round too compare with.
Old 06-23-2005   #6
There are other threads about porting a stock carb they say to use a 9/16 drill to port your carb I found that to be to big I use a 35/64 bit that brings the bore to 14mm and is perfect for slide fit. Also some racing classes don't allow a carb bigger than 14mm. I find these carbs to work better than most after market carbs out there.
mrmuffinmanvw is offline   Reply With Quote
Old 06-23-2005   #7
merctech's Avatar
good news I think?
Well I tried the carb on my other bike which is completely stock, my bike is in pieces. With the slide all the way down it idles low enough with pressure on the bike it just barely wants to move, thats with all stock jets and needle in stock position, so if I adjust the needle to the 5th position that would fatten up the idle mixture a little right. Which would probably lower the idle a little more, please correct me if Im wrong. On a another note Im getting the banshee clutch for cags so even if I cant lower the idle anymore I can have the clutch engage later so it wouldnt matter the idle is a little high.
Old 06-23-2005   #8
hayabusa's Avatar
glad to see that the idle isn't too bad that the bike wants to take off on its own. true that the 5th may help with the high idle but then again, the bike may run rich throughout the rest of its throttle... performance "may" differ with the needle in the 5th.
I'd go head with the banshee adj clutch. it will give you a better neutral spot for your idle, plus you can adjust the clutch to respond better, stronger launch!
Old 06-23-2005   #9
merctech's Avatar
Thanks for the advice guys. When I get her back together then we'll really see.
Badazztoys C1 17mm carb review BungeeGuy Water Cooled Pocketbikes 38 06-29-2005 11:09 PM
Jim Adams Banshee Pipe And Dellorto 21mm Carb Review!!!! NITROMUNCHER Water Cooled Pocketbikes 15 05-24-2005 11:13 PM
major carb problem w/ HP carb need Help chulomc9 Air Cooled Pocketbikes 2 03-06-2005 11:19 AM
My Cag won't start (Carb Clog Problem) onedownfiveup Air Cooled Pocketbikes 14 09-24-2004 01:27 AM
Page generated in 0.21466 seconds with 42 queries
