Old 09-13-2004   #1
Carburator Porting
What size do I port the carb to?
Also, do you port all the way through because I see this brass hole where the needle goes in(main jet?)?.
Can I remove it somehow?
And last, I remembered I saw some picture posted of ported carburators, can anyone post the pictures again, I can't seem to find them in the forum?
Twitch is offline   Reply With Quote
Old 09-13-2004   #2
i can make it easy for ya just buy mine! look in classified section
Old 09-13-2004   #3
badazztoyz.com's Avatar
use a 9/16 bit but dont go past where the circular wall is where the slide goes..follow up with 220 then 440 grit sand paper
Old 09-13-2004   #4
SUX2BU's Avatar
why don't you wanna go past where the slide goes?
SUX2BU is offline   Reply With Quote
Old 09-13-2004   #5
snowboardgeek1's Avatar
Because you can pop through to the fuel vein, and it lets in way too much air to the carb where you'll have a hard time to hold a good idle.
Old 09-13-2004   #6
SUX2BU's Avatar
i ported mine to about 15.5 mm (about 5/8") all the way thru and it idles great.
Old 09-13-2004   #7
Did you take out that brass thing(where the needle goes in) in the middle of the carb before you ported it all the way through?
Old 09-13-2004   #8
MikeM's Avatar
I went all the way through with the 9/16 and it idles fine. If you go all the way through, make sure you drill the plastic manifold too.
MikeM is offline   Reply With Quote
Old 09-13-2004   #9
SUX2BU's Avatar
yeah i took everything off before i hogged it out. and then cleaned the hell out of it, put it back together and it rode great. i don't know if it made an improvement or not but it pulls great.
Old 09-13-2004   #10
Ok, but won't the hole be too big for the slider? Won't there be space on each side of the slider?
Also, I read that the intake inside can be polished smooth, but the side after the carb, the surface should be textured because if it's smooth, the fuel might bead up. So what sand paper grit should I use for the side after the carburator?
Old 09-13-2004   #11
SUX2BU's Avatar
yeah there is space on either side of the slider which makes it idle higher. but in my case i just turned the idle screw to where it was not affecting the idle and it idles perfect.
Page generated in 0.23748 seconds with 48 queries
