Old 10-01-2009   #1
chain questions
i havew a 49cc cag, what is the stock chain on this? and what is a 25h chain? how long is the stock cag chain?
tschulz is offline   Reply With Quote
Old 10-01-2009   #2
Re: chain questions
the chains for the cags are the 25h chains. the stock length of them vary (some are shorter and some are longer) all depends on your setup.
merlin48066 is offline   Reply With Quote
Old 10-01-2009   #3
Re: chain questions
how do know when your chain is to tight or to loose?
Joe RSR is offline   Reply With Quote
Old 10-01-2009   #4
Re: chain questions
you have to feel the slack in the chain there is a happy medium. once you tighten the chain wiggle the chain up and down and side to side. this will tell you how much slack (lose or tight) is in the chain. dont tighten the chain too tight cause you will strip out your front sprocket. i have proof of that to. after you set the chain with the motor off take the tire and turn it as fast as you can in both directions. if the chain pops off its too lose. if the chain doesnt pop off you might have the sweet spot or if the tire is hard to turn then you have the chain too tight. a good way to get a bench test on how fast or slow the wheel should turn is by taking the chain off and let the wheel spin freely. when the chain is on the wheel will not spin as fast or as long as it does with out the chain. thats normal.
Old 10-01-2009   #5
Hooligan
SpyGuy's Avatar
Re: chain questions
Also if you have your chain too tight, you can actually "sawtooth" the rear sprocket on your bike. I have a gear off a GP RS-R that a kid did exactly that to .... those teeth are razor sharp from the friction against the chain.
Old 10-02-2009   #6
Re: chain questions
Thanks im waiting for my new chain to come in the mail last one bent when it came off while trying to brake in motor took a nasty spill but im new and still learning thanks again for the info
Old 10-05-2009   #7
Re: chain questions
Chain just came today and it is too small, now I have to wait another week n 1/2, 2 weeks or at least it feels that way for them to send me a new one or the right one. Sucks to be me right now
Old 4 Weeks Ago   #8
Re: chain questions
was there no way to fix the chain? mine jus broke having difficulties repairing
porsche23 is offline   Reply With Quote
Old 4 Weeks Ago   #9
Hooligan
SpyGuy's Avatar
Re: chain questions
Easiest way is to get a chainbreaker ... Dave's sells them for $15.00 apiece, and to me, they're worth it. Put in PBP as the coupon code, and get 5% off your order.
Old 4 Weeks Ago   #10
Re: chain questions
easier to just order new chain? or no
Old 4 Weeks Ago   #11
Hooligan
SpyGuy's Avatar
Re: chain questions
Yes and no. If you know the correct length to get, yes. If you need to "make your own," then you can order chain by the foot, and use the breaker.
Page generated in 0.35624 seconds with 48 queries
