Old 08-25-2004   #1
Soulranger's Avatar
Question Destroyed chain rollers..replacement ideas??
My chain completely wore my chain rollers in half. I don't know if my chain was too lose or it was because my foot pushed so hard against the chain guard and got them out of alignment. I also ruined my chain guard, once again because my foot pressed the guard into the chain where it goes to the pinion gear. Any ideas on replacing this stuff and remedies so it does not happen again??
Thanks,
Ross
Soulranger is offline   Reply With Quote
Old 08-25-2004   #2
woof's Avatar
I would just buy another set...and the chain gaurds are fairly cheap....Maybe the chain was too loose...
woof is offline   Reply With Quote
Old 08-25-2004   #3
Soulranger's Avatar
Wow...quick replies dudes...I did not know ADA had them thanks for the tip. Yeah I think my chain stretched a bit and got too loose. Any ideas how I can keep the chain guard from pressing into the chain?? I try not to press too hard but it just seems to happen.
Ross
Old 08-25-2004   #4
jsigone's Avatar
those ADA delrin ones looks NICE
Old 08-25-2004   #5
Soulranger's Avatar
Thanks again guys...yeah thats what I was trying now..putting some washers between the guard and the rollers. My guard is really jacked-up from the chain/gear tearing a small hole in it and from me bending the hell out of it to try to keep it away. I will need a new one.
Ross
Old 08-25-2004   #6
SDR1DER's Avatar
I remember someone saying they had bearings for chain rollers. Anyone have any experience with such a setup? Mine are almost toast and i'm looking for some type of upgrade. How do the delrin ones hold up?
SDR1DER is offline   Reply With Quote
Old 08-26-2004   #7
mega's Avatar
here it is :
my quick design. works very well!
mega is offline   Reply With Quote
Old 09-02-2004   #8
mel mouser's Avatar
I had the same problem with the plastic guard. I made a new from aluminum using the plastic one as a template for the mount holes. I also extended it forward so I could use the threaded hole just forward of the clutch in the eng. case, made a little L-angle bracket to attach at the forward end , on the top of the aluminum I bent it 90 degrees for some strength and it is holding up very good . looks kind of like a bicycle guard but my chain isn't rubbing and my foot can push hard on it with-out worries.
mel mouser is offline   Reply With Quote
Old 09-06-2004   #9
Has anyone bought the "Chain guide /guard Steel GP" or "Chain guide block" from Adrenalinemotorsports.com bcuz im looking for some chain rollers and im already ordering some stuff from there so i was wondering if they are chain rollers or not?
Thanks
Zacritz929 is offline   Reply With Quote
Old 09-06-2004   #10
whats the point of the rollers? my cag doesnt even have any and i havent noticed any ill effects from it
cjmatt is offline   Reply With Quote
Old 09-06-2004   #11
(RedBlur)'s Avatar
. . . nice!
(RedBlur) is offline   Reply With Quote
Old 09-10-2004   #12
Cool chain rollers
yes mine was bad also ,but i made some at work last night when i get home i will post some pics of them for you, let me know what you think of them.
LHUDGINS is offline   Reply With Quote
Old 02-19-2005   #13
gurt's Avatar
i had the same problem with my bike. all i did was put some washers between the gaurd and rollers and it works fine. as for the rollers and the new gaurd im pretty sure you can get them from midsouthminimoto.com as well as many other parts.
gurt is offline   Reply With Quote
Old 02-19-2005   #14
guy on the couch's Avatar
i used some old fuel line in place of the roller. just cut it to fit. has worked wonders ever since and, was inexpensive as well as quick.
seeing how they just get chewed up by the chain anyways its ideal in my opnion. you can get 2ft of 1/4 in or thinner for like 2 or 3 bucks.
guy on the couch is offline   Reply With Quote
Old 02-19-2005   #15
Spud Warrior's Avatar
I just took mine off, the chain only touches the metal bars now when the bike is sitting still so that doesnt do much. I was tired of how they rattled and made alot of noise.
Spud Warrior is offline   Reply With Quote
Old 02-19-2005   #16
ayeWTFisthat's Avatar
i have meathooks on my cag so i dont even have to use a chain gaurd or rollers...
ayeWTFisthat is offline   Reply With Quote
Old 02-19-2005   #17
daniel's Avatar
what does meathooks have to do with not using a chain guard or rollers ?
daniel is offline   Reply With Quote
Old 02-20-2005   #18
because all the chain guard does is protech your feet from hitting the chain and my feet dont even get close to the chain...
Chain rollers!!!!!! Deputy Dawg Air Cooled Pocketbikes 3 06-24-2005 02:24 PM
How To: Fix Your Chain Rollers for $1 eaterofdog Air Cooled Pocketbike How-To's 0 04-05-2005 08:27 PM
Auto Chain Tensioner? Redrodent Air Cooled Pocketbikes 13 03-02-2005 09:01 PM
chain tension / rear axle bolts / froze link. rampbrian Air Cooled Pocketbikes 5 10-14-2004 01:44 PM
Replacement chain zargon Air Cooled Pocketbikes 3 08-25-2004 04:57 PM
Page generated in 0.33205 seconds with 70 queries
