Old 09-24-2004   #1
Mischief's Avatar
Question Different Clutch, No Timing key ????
K, I just bought a rocket key and the (3) race clutch springs (or so the store called it) upon opening the clutch cover.........HMMMM.....There's only one spring in the middle holding the clutch together. I was like OK, so I remove the clutch and no woodruff key to replace with the rocket key.
I've only seen the clutches with the three springs circling the clutch and in the back followed by the woddruff key. Is this type of clutch bad, can I replace it with the standard clutch or would the tranny not accept it because there is no place to put the woodruff key...
Also the pinion gear ripped from clutch housing......which sux...is this caused by this type of clutch
please help
Mischief is offline   Reply With Quote
Old 09-24-2004   #2
woof's Avatar
I just ran into this at the races.....my clutch broke all apart...So I went to change the complete clutch assembly....the new clutch set up had no groove for the woodruff key....so I just took out the woodruff key...and put on the clutch...tightened down ...and was good to go.....
Just to clarifiy....Rocket key is on the pullstarter side...It's to advance the timing...Some guys said it didn't do any good...so they took it back out....That's only what I heard...
woof is offline   Reply With Quote
Old 09-24-2004   #3
you dont need the key in the clutch, it will be ok as long as you tighten it up really good, the rocket key goes on the flywheel side.
the pinions do break, that is just the quality of it, but i have a pretty fast motor and i havent broke one, just rough riding will do it and if your chain is not set right.
pupuslinger is offline   Reply With Quote
Old 09-24-2004   #4
Mischief's Avatar
K, feel silly now..........XD, yes I just found out the rocket is installed on the opposite side, d'oh........but as for the clutch is there a big difference between the triple spring one and the single spring...........thanks for the replys..=0
Old 09-24-2004   #5
woof's Avatar
The only ones I've ever seen have 3 clutch springs...
Old 10-03-2004   #6
Club PBP Member
B G Motorsports's Avatar
Mischief what kind of bike is it?HF,FF,orsuper or cateye?
B G Motorsports is offline   Reply With Quote
Old 10-04-2004   #7
Mischief's Avatar
The bike is an HF, but I just heard is that the clutch looks like a cateyes cltuch which has the single spring in the middle. By the way the bike is on the Evelocita post.......just got to search option Evelocita.....pics are on the 5th page i think
Old 06-29-2005   #8
hold the crank and turn the flyeheel in the direction of engine rotation until the key fits
It advances the timing
GSXXRR is offline   Reply With Quote
JUST GOT WALBRO CARB,JETPRO PIPE,ROCKET KEY & CLUTCH SPRINGS NOW BIKE IS SLOW AS HELL MINIMADNESS 2Stroke Midbikes 21 02-24-2005 11:45 AM
Timing key question ExtremeBoutch Air Cooled Pocketbikes 7 02-09-2005 07:05 AM
Timing key SilentX1 European Pocketbikes 0 02-07-2005 09:23 PM
Stock timing key? xxtremez Air Cooled Pocketbikes 4 01-27-2005 08:55 PM
rocket key advanced timing and carb tuning pEsCaDoR 2Stroke Midbikes 4 10-09-2004 12:12 PM
Page generated in 0.24294 seconds with 39 queries
