Old 10-17-2004   #1
Dave_O's Avatar
fiberglass...or carbonfiber and couple of questions
ok i have a hf cag...
if done a seach so every1 doesnt **** at me.
ok im lookin to upgrade my reeds, i want more top end....so i was thinkin .03 instead of .05 because the 5's are stiffer, which 1 should i get for more top end.
also i was wondering what would be better carbonfiber? or fiberglass?
i was looking to buy some online but they didnt tell me if it was .03 or .05 ???
does the billit in line fuel filter replace the stock fuel filter right above the on off gas valve? and worth buying?
Dave_O is offline   Reply With Quote
Old 10-18-2004   #2
Hugs not Drugs!
vehement's Avatar
well, the .5 is for top end. the carbon fiber ones are compairable to .5, so they are also for top end. it all really depends on your setup, if you have the 1pc .3 reeds, then you can take out the middle bar on your reed block and it will flow more than stock and the ADA reeds.
vehement is offline   Reply With Quote
Old 10-18-2004   #3
Dave_O's Avatar
sorry i ment i wanted more bottom end not top end....so that means i should get .3 right? but i cant find on any website .3 for a 47cc cag
Old 10-18-2004   #4
get the .5s and then get a reed spacer. The spacer will add to your low end and still have top end with the reeds.
fstbusa is offline   Reply With Quote
Old 10-18-2004   #5
Dave_O's Avatar
is that possible to do?
Old 10-18-2004   #6
Dave_O's Avatar
maybe you can help me with another problem....everything is good but my bottom end, it takes awhile to get up to speed and sounds like a fart can not a bog but just like a 4 stroke sound, and i have the rocket key installed... oh yea does it matter if you have a 49cc rocket key in a 47 cc pocketbike iunno if there the same or not
Old 10-18-2004   #7
same thing but different companies keys might advance it slightly different amount.
Page generated in 0.22411 seconds with 35 queries
