Old 1 Week Ago   #1
Front sprocket noob question
hey guys.
my 49cc giovanni has a 6 tooth front sprocket. i found one of my 47cc part bikes had a 7 tooth front one.
what difference is there? if i put the 7 on mine, would i gain top end? or acceleration?
i tried searching, but i'm on my iPhone, and it crashed both times i tried.
thanks in advance, guys!
GardenBeast is offline   Reply With Quote
Old 1 Week Ago   #2
013137's Avatar
Re: Front sprocket noob question
The higher the number of teeth on the front gear = more top speed and less acceleration
And the higher the number of teeth on the rear sprocket = more acceleration and less top speed
Old 1 Week Ago   #3
thank you sir!
i had it backward in my head. excellent. i think i MIGHT put this on. always nice to have a choice, anyways.
thanks again.
Old 1 Week Ago   #4
013137's Avatar
No problem, I'm running a 7 tooth in the front and my bike has all around great performance, so I recommend the 7 tooth.
Old 1 Week Ago   #5
oh hells yeah. my bike is quite a bit quicker. my friend used to pull away from me. now i pass and pull away from him.
i think combined with the lightened flywheel i did at the same time, i gained top end AND acceleration.
Old 1 Week Ago   #6
Hooligan
SpyGuy's Avatar
For future reference,
-front gear = pinion
-rear gear = sprocket
Whenever poeple talk about gearing on their bikes,and you see a combination like 7/68, that means a 7th pinion on the front, and a 68th sprocket on the back. These combinations are endlessly changeable, depending on your riding style and what you're using the bike for. For instance, a taller sprocket (more teeth) will add to acceleration, but lower top end.
Old 1 Week Ago   #7
013137's Avatar
^Yep, and I'm going to change my rear sprocket soon, so just to make sure, every 3 teeth on the rear sprocket = 1 tooth on the front pinion correct?
Old 1 Week Ago   #8
Hooligan
SpyGuy's Avatar
Not on a Cag, dude ..... by your formula, that would be a 6th pinion and a 18th sprocket, and I don't even think they make sprockets that small ....
Cags generally go by the "Rule of Ten." For every single tooth on the pinion, there should be ten (ish) teeth on the sprocket. 6th pinion, 60(ish)th sprocket, 7th pinion, 70(ish)th sprocket, and so on .... (Found this info on another pb site ... sounded reasonable, so I brought it over here.)
Old 1 Week Ago   #9
013137's Avatar
Dammit I just wasted money ordering a 64 tooth sprocket thinking that it would be almost equal to me putting a 8 tooth pinion on my bike. I heard that calculation somewhere, and I just ran with it lol. So I would have to use about a 58 tooth sprocket right?
Old 1 Week Ago   #10
013137's Avatar
Well I just ordered a 62 tooth sprocket.
Old 1 Week Ago   #11
Hooligan
SpyGuy's Avatar
Where did you hear that 3-to-1 calculation? That might work on a goped (actually, it kinda does - the Re-Cycle gearing is a 25th pinion on the CVT, and a 55th sprocket on the wheel .... almost 2:1 gearing).
You should be cool with a 7/62 or 7/64 ... a 58 is just a little too low for takeoffs and acceleration, although top end would be prety interesting. My race bike is running 7/68, seems to pull just fine with that range.
Old 1 Week Ago   #12
013137's Avatar
Hmm I'm not exactly sure where I heard it from, but I surely heard it before, and more then once.
Here is 1 of the places that mention it:
Sprockets & Speed - Pocket Bike Forum
(I hope it's not against any rules to post this link)
^Oops I just read through it all and it seems that they are talking about super pocket bikes, so I guess that's where I got all of my confusion from.
Yea I'm running 7/68 right now and my low-end is too powerful, which makes the top end feel slower then it actually is, because it gets there pretty fast in about 5 seconds.
Old 1 Week Ago   #13
Hooligan
SpyGuy's Avatar
PBR.com.au .... good site. I'm on there, too. Good link to that gearing chart - that helps a lot in explaining gearing ratios.
(That's pocket-bike-racing.com.au for you guys who are interested. Australian site, mostly euro bikes, a few Cags here and there.)
Page generated in 0.29297 seconds with 54 queries
