Old 11-05-2009   #1
mnibike's Avatar
Help!
I need to know where I can purchase some STRONGER and better quality wheel bearings. The stock ones arent just working for me. I've busted 2 already. Pretty scary, I know. Thanks
mnibike is offline   Reply With Quote
Old 11-05-2009   #2
SPB Mod Master
Re: Help!
WW Grainger,Boca Bearings and surplus center are a few places to get good quality bearings...................Peace
Old 11-05-2009   #3
Hooligan
SpyGuy's Avatar
Re: Help!
How did you break them? Over-tightening, or riding?
Old 11-06-2009   #4
mnibike's Avatar
Re: Help!
wait???? over tightening? well i riding it when they broke but i did tighten the axle quite a bit
Old 11-07-2009   #5
Hooligan
SpyGuy's Avatar
Re: Help!
Okay, yes, you can break the bearings from over-tightening. Usually, there's a metal spacer that goes inside the wheel from the inside of one bearing to the inside of the other, and the bearing rest against this. What can happen is, when you're tightenening up the wheel without this center tube, you're actually trying to pull the insides of the bearings towards each other, which can make them buckle inwards and eventually fail.
What you can do is find a tube that will fit over the axle, and is about the same size as the lip of the center of the bearing. Take your wheel off, and take out the bearings. Now, look at where the bearings go into the rim - see that little lip? It's a stop so the bearings stay on the outside. Measure from one stop to the other - that's how long you need to have that tube cut to fit inside the wheel bearings when they're installed.
Old 11-08-2009   #6
mnibike's Avatar
Re: Help!
Thankyou spyguy. I installed a inner wheel tube, put in another stock bearing, avoided over tightening the axle and voila! Everything works well and no signs of wear on the bearings. Thanks again
Old 11-09-2009   #7
Hooligan
SpyGuy's Avatar
Re: Help!
Been there, done that ... that's how I figured out what had happened. It's called "pre-loading."
Old 11-09-2009   #8
Doc Loveless's Avatar
Re: Help!
what size bearings do the big X bikes use? do have to be anything special or can i just use skateboard bearings for mods
Doc Loveless is offline   Reply With Quote
Page generated in 0.25380 seconds with 38 queries
