i have a brand new x18 110cc super bike my lights were working perfectley then everything started not to work from lights to horn signals and electric start i bought a battery tender and i been charging it for almost a day now im wondering of a good estimate how long does it usually take to be completed
well if the battery tender hasnt shut off automatically then your battery might be shot and it isnt holding a charge since it takes about 4 hours for mine to charge with a battery tender, check your fuse like buzzkill said then if its good check the wires
Yeah, if your fuse is good, then check the wires and the connections, you could possibly have a short in the system. One of the power lead wires might be grounding somewhere. If a power wire rubs against an edge somewhere it'll short out and run the battery down quickly and charging it will have no effect on the battery, because the juice will go right into the frame and not the battery.
yeaa um i changed my fuse and i tryed to charge my battery it it wouldnt say charge so i guess my battery is dead so i bought a new and um is it true when you kick start your choke should be on
just to let you guys know the x18's have a stator that charges the battery as you ride. it also powers the lights and all that too! the battery's mostly there just to start the bike. so if you've been riding and the battery's going dead you either have a short or bad battery. or the terminals aint tite!
i would start with the battery cuz the china batterys are crap they dont last very long to begin with. i heard walmart carries a better battery for cheap. plus x18's arent the ones that are known for shorts its the x19's that short and burn to the ground. not saying its not a short just highly unlikely unless you wrecked or something?
most dont even need to use their chargers for the x18 it only needs charged if it hasnt been ridden in a while or fresh out the box. and if your bike is tuned properly it should fire first kick!
