Old 05-02-2008   #1
ultracag2's Avatar
how to install reeds for new bikers.EASY
Hello. for those new bikers that just started and want to start modding their bike im going to tell you how to properly change your case reeds.
first im going to tell you where they are located. Case reeds are located before the carb. They have a metal plate that they are screwed onto.
first what you are going to do is take the air filter off. if you have a stock carb it should be 2 screws to take out usually phillips head. take those off. lay the air filter on a surface that the air filter will not get dirty.
carefully clean the carb intake so that you will not clog the carb with any dirt or sand particles.
take the right size hex key and unscrew those bolts. when the screws are finally out carfully take the carburator off and lay down on a surface with no dirt.
now you will see a black manifold (if stock carb) and you will see 4 screws. take the right size hex key and CAREFULLY unscrew those and make sure not to damage the gaskets!!
TAKE NOTE OF WHERE THE SCREWS ARE (top or bottom of crankcase for installation)now you should see a flat plate which looks like 2 screw ends coming out. if your case reed block does not fall off or come off. clean the area free of any dirt or grime even your hands! push the stock case reeds in gently enough to get a hold on the reed block and pull up gently, or what ever direction you have your bike on.
TAKE NOTE OF THE CUT CORNER ON THE REEDSyou have your reed block with stock reeds. make sure you get the right size phillips screw driver and start unscrewing the screws that hold the stock reeds and reed stops on. now take your new reeds and make sure your cut corner on the reeds goes onto the correct side.
carefully screw on DO NOT OVER TIGHTEN just tighten tight but not too tight, because you dont want to strip the screws.
__________________________________________________ _____________
installing new reeds
gently whipe away any dirt and greese from the gaskets and sand.
start to install the reed block as you should have taken note of which way your reed block came off.
carefully start to put the manifold on and dont shove the screws through the hole as you will probably rip the gasket.
tighten the manifold tight but dont over tighten.
install the carb and tighten the screws.
install the airfilter and start the engine up and when started let warm up and take for a ride but not long as we are checking if engine is running lean or rich.
run WOT, WOT means wide open throttle. for 15-20 seconds as this will not damage your engine.
take the spark plug out and check to see the color of the tip color
black=really rich
dark brown=rich
brown=good
light brown=good=perfect
tan=good=perfect
white= bad you are too lean
you want to stay within the brown to tan section or any thing that says good to perfect
any other questions just ask.
ultracag2 is offline   Reply With Quote
Old 05-02-2008   #2
Council Member
Juanitoboy93's Avatar
Re: how to install reeds for new bikers.EASY
Hey good job, maybe this will help out a lot of newbs
Old 05-03-2008   #3
matty boi's Avatar
nice good job!
matty boi is offline   Reply With Quote
Old 05-03-2008   #4
ultracag2's Avatar
thanks! i tried to be as descriptive as possible.
Old 05-03-2008   #5
ultracag2's Avatar
Originally Posted by matty boi View Post
nice good job!
thanks! its very correct right?
Old 05-03-2008   #6
You got it bro hows that cag a running
capt highsider is offline   Reply With Quote
Old 05-03-2008   #7
ultracag2's Avatar
yea I spent a while writing that. Yup its running great I got some of the "fix a flat" and its holding alot longer but still leaks slowly but not able to hear it. Its pretty fast I might make another video tomarrow but just a ride down the road
Old 05-04-2008   #8
davation's Avatar
One thing you forgot to mention. When the reed is installed properly, the port holes will be closed by the reed in resting position.
davation is offline   Reply With Quote
Old 05-04-2008   #9
ultracag2's Avatar
that's true well if I ever get a question about that then there's my answer
Old 05-05-2008   #10
X19_S2_Owner's Avatar
Im a newb to pocket bikes/super pocket bikes!!!! So thanks for that info,it should help quite a bit.
Waiting on my X19 S2 Super Bike to get here and also waiting on my X7 Super Bike to get here as well. Forming a Super Pocket Bike Club here in greenfield indiana! Just spent $1032.00 shipped for both,they'll be here anyday now. :-) also got me a couple of those Mini Harley Chopper 49cc bikes,both brand new and i got them from a guy that lives near me.
X19_S2_Owner is offline   Reply With Quote
Old 05-05-2008   #11
davation's Avatar
awesome dude! Good luck with your club.
Old 05-05-2008   #12
ultracag2's Avatar
your welcome. and good luck!
Old 4 Weeks Ago   #13
That was really good man!
underglow94 is offline   Reply With Quote
Old 4 Weeks Ago   #14
do u have 2 up jet the crab iff u put reeds in
ashley blata is offline   Reply With Quote
Old 4 Weeks Ago   #15
on my bike i didn't have to. but if u didn't already know the bike comes with reeds already in it so unless the are not working good or u wanna upgrade u don't have to get any.
varsity linemen is offline   Reply With Quote
Old 1 Week Ago   #16
mark3631's Avatar
i was going to install my reed, and when i was takein it all apart, the reed bracket fell off, so i didnt see what way it goes in, is like a U or like n
mark3631 is offline   Reply With Quote
Old 1 Week Ago   #17
Hooligan
SpyGuy's Avatar
When you put the reed block and reed stop back together, the screws should be on the top. There's a flat piece on the reed stop that sets against the reed block, sandwiching your reeds in between.
Why isn't this thread a sticky?
Old 4 Days Ago   #18
mark3631's Avatar
((((TAKE NOTE OF WHERE THE SCREWS ARE (top or bottom of crankcase for installation)))))))
sorry but maybe i didnt make my self clear, i didnt see where it was placed it feel off, i have it with the screews on top, but it takes a while for it to get up and go. and it spudders to get going, is this a case of screews should have be on the bottom
Old 4 Days Ago   #19
Hooligan
SpyGuy's Avatar
Screws go on top.
Sounds like you may need some better reeds in your bike, Mark. Replacing the stock tin reeds with carbon fiber or fiberglass ones (I prefer the CF ones myself) may help out.
Old 4 Days Ago   #20
Outlaw
EPR's Avatar
Mark,
Carbon Fiber dude, I think $10 a Dave's, and cut the top off the reed blocks grind back .050 or .060 of an inch on the same arc to the bottom
off the reed stops, lets your reeds open 1/16th father, works good with
CFs.
SpyGuy, put a .70 jet in #3 eng. adj. the float arms down aliitle, got the CF reeds & ground reed stops. She runs good now, the twin boost tubes are probably too much, but I will split them when they go on the 2 Drag Engs & the extra manifold fitting w/ be hook to the NOS Trigger, Yea haw.
Hell, I might get to the C1 before April!! EPR!
EPR is offline   Reply With Quote
Page generated in 0.32845 seconds with 74 queries
