Hey man, i don't like the boost bottle size, so what you say? well, I have some software that will maybe make you a better one, tell me what hose size you want to use and i will run it for you. Also, where did you get the 1.5's from in aus? no links just say it. Did you put a timing light on before the coil mod? what degrees was it and how do you know it's 8 degrees?
Originally Posted by auscooter I have a gen 2 cag. Have been reading threads in this forum for a while and decided to try some mods.
- ADA .325 reeds
- walbro wt215 carb
- 20ml boost bottle
- advanced ignition coil 8 degrees
- 6/72 gearing
- ngk sprk plug
- finer filter air filter
- 1.5 clutch springs
- 4th bearing kit
- modded stock pipe
All this I done for very little money and a bit of time. The carb i got from the local mower shop secondhand and rekitted it, cost 20$ all up, boost bottle is made from a asma inhaler, advanced the timing by slotting the holes in the coil and modded the stock pipe by cutting 50mm from the header and adding 50mm to the chamber.
I am the heaviest(215lbs) of all my mates with them and can out accelerate and match their top speed easy. Stronly recommend the pipe mod. |
