Originally Posted by vinnie sounds good but $145 is a little too steep. ip2 pipe performs just as well and $45 less in price. |
First of all, Mike's prices are better than ANY i've seen for a JetPro. Whether or not its overpriced in comparison to the IP2 is another story. I have the IP2 as well, and it does NOT perform 'just as well.' Its a completely different pipe, that is designed for a completely different application.
If you race tight tracks, or parking lots, and need the bottom end kick out of turns, well you're **** outta luck with the IP2 unless you have some crazy expert tuning skills, or one beast of a motor. But with JetPro, stock bikes can rip outta turns.
If you race more open tracks or just like a lot of mid/top end kick then IP2 is for you. The JetPro cannot compete with an IP2 in mid/top end pull, but an IP2 doesn't have a prayer against the JetPro off the line, especially with a stock motor.
So...you really can't compare the price of the two unless you're looking for mid/top performance, then the decision is a no-brainer--IP2.
