Old 08-25-2004   #1
Exclamation Let's rebuild the Full Circle Stroker Crank HOWTO sticky
Here are the pictures courtesy of lucky topher z28 who did the original writeup of the IP2 FCS crank install. How about the experts who have attempted or know how to do it post comments on each one, and then we can have an admin copy and paste the bastard to make sense out of it. That was one of the best 'stickys' we had.
http://home.earthlink.net/~mcg.jr/pix/crank1.jpg
http://home.earthlink.net/~mcg.jr/pix/crank2.jpg
http://home.earthlink.net/~mcg.jr/pix/crank4.jpg
http://home.earthlink.net/~mcg.jr/pix/crank5.jpg
eldevioso is offline   Reply With Quote
Old 08-25-2004   #5
Old 08-25-2004   #6
is the full circle crank so the bottom end is ballanced and it can rev higher while at the same time not vibrating the $%^* out of the bike?
Old 08-25-2004   #7
I think that's partly it..but i think the crankmoves farther giving it a longer<?> stroke...
Old 08-25-2004   #8
guy on the couch's Avatar
Thumbs up case?
you have to smooth out the corners circled on the case to make the shaft will complete rotation witout collison/interference with the case?
helpful indeed
guy on the couch is offline   Reply With Quote
Old 08-25-2004   #9
oh so its a stroker crank as well?
Old 08-25-2004   #10
Yup, +3mm over the stock stroke.
shultzy1969 is offline   Reply With Quote
Old 08-25-2004   #11
See
Got mine done the other day.If you are capable of tearing down the motor and putting it back together it is really easy to do theres not that much of the crank case that has to be removed.The end results are worth it I would say definetly worth the price.
See is offline   Reply With Quote
Old 08-25-2004   #12
Kevin's Avatar
Big Bore KIT porting only done on exhaust port;
with stock crank:
widen to 31 mm
raise roof 2mm
with SFC
exhaust port :
widen to 31 mm
raise roof 4mm
lower floor 1mm
warning :dont try to match exhaust chanell with port size or channel can bust open (holed) , so you can tapper cut only
SFC instalations:
veriaty of cylinders out there made by different companies so squish clearance can vary
squish band must be set at 0.5mm :
less than that means piston hit the head , any more will reduce compresion and engine will not make any power or may not even run ..
on most engines 2mm spacer should not be used , instead stack 3 to 4 base gaskets , each gasket is 0.3 mm so 5 will be 1.5mm .. some guys used only 3 gaskets ..
if more than 5 required then must use 2mm spacer and no gaskets ..use yamahbond 3 to seal ..
never use any type of sealant or paste on paper gasket , because when stacked the sealant may cause it to slide sidways
you may use smallest amount on case joints only
forward this to anyone with FCS crank:
1- case must be trimmed to make 0.5 clearance between crank and case,..can trim with half moon hand file , must trim at 45 degree angle , only cut from case centers
2-must instal spacer supplied or gaskets under cylinder
3-must remove the washer on 4 cylinder bolt so bolts can reach deeper
4-it maybe possible to run without base gasket as long as piston dont hit the head , in this case use small amount of yamabond 3 to seal ..check all clearances , 0.5 clearance on all parts required , if piston hit the head add one or 2 base gaskets till it clear
5-stroker crank increase dispalcement to up to 54 cc so is vibration , make sure there is rubber mount on pipes mount and all fasters torqued down
6- must port cylinder and instal pipe and jet kit
7- my pipe sold out so you can modify stock pipe as follows:
cut 1inch from header , add 1inch to belly , such mods make more torque than my pipe for indoor but fall short in outdoor tracks
Kevin is offline   Reply With Quote
Old 08-25-2004   #13
BrainDrain_dx's Avatar
http://www.dx4life.com/pocketbike/fcs.htm
Start typing
hope to start my own install tonight and cover everything including setting the squish. Plus add new pictures. Anyone who wants to add anything email me braindrn@cox.net
thanks,
Brain
BrainDrain_dx is offline   Reply With Quote
Old 08-25-2004   #14
WFO Racing's Avatar
Before you bolt it all togeather, do a squish test and adjust base gasket for a .5mm squish. This is EXTREMELY important!
Use a piece of lead solder and place it on the piston over the wrist pin.
Turn motor over by hand slowly.
Remove solder and measure it with calipers.
Target .5mm
In order for me to get .5mm, I had to remove the spacer and double up two gaskets I made which are thicker than stock.
This was a HUGE difference in performance.
With the spacer I had 1.2mm squish and 120 lbs compression.
Without the spacer and using two gaskets I made, I have .5mm squish and 180 lbs compression.
WFO Racing is offline   Reply With Quote
Old 08-25-2004   #15
mega's Avatar
heres more what WFO is talking about:
mega is offline   Reply With Quote
Old 08-26-2004   #16
when assembling the circle crank do you reuse the lower crank/rod pin or does the kit come with a new one? if not, am i going to need a machine shop to press the 3 pieces together? the reason i'm asking is cuz i'm worried about alignment and crank assembled out of balance from the get go.
whiskey is offline   Reply With Quote
Old 08-26-2004   #17
WFO Racing's Avatar
The crank comes with the connecting rod assembled so all you need to do is add your piston.
Old 08-26-2004   #18
thanx
dude thats too easy, $60 is complete. you can't beat that. i hope it's on my door step when i get home tommorow. i won't be able to sleep tonite!
Old 08-27-2004   #19
oh its only 60 bucks, Ill have it sooner than I thought.
Old 08-30-2004   #20
hayabusa's Avatar
$60 from where?
hayabusa is offline   Reply With Quote
full circle stroker crank loopedout36 Air Cooled Pocketbikes 12 04-21-2005 09:40 PM
Full Circle Crank M J D Air Cooled Pocketbikes 6 02-05-2005 01:25 PM
What's the truth on the FULL CIRCLE STROKER CRANK? Demtoofast Air Cooled Pocketbikes 43 12-09-2004 12:45 AM
My C1 Crank Is Full Circle!!! Demtoofast Water Cooled Pocketbikes 2 10-26-2004 09:17 PM
Full Circle Crank Results? karrumba Air Cooled Pocketbikes 13 09-04-2004 09:23 AM
Page generated in 0.37958 seconds with 76 queries
