| Re: more spark plug questions looks like the only difference is the removable terminal that you can unscrew Im also thinking this plug has a little more total height from the base to the terminal like 10-15mm more
BM6A
14mm Thread, 9.5mm (3/8") Reach, 3/4" (19mm) Hex Size, Gasket Seat, Non-Resistor, Solid Terminal, Compact Small Engine Plug, .027" (0.7mm) Gap, Heat Range 6
BPM6A
14mm Thread, 9.5mm (3/8") Reach, 3/4" (19mm) Hex Size, Gasket Seat, Non-Resistor, Removable Terminal, JIS Height, Projected Tip, Compact Plug, .027" (0.7mm) Gap, Heat Range 6
