Old 03-28-2005   #1
Nashport_Native's Avatar
my boost port numbers
here is my boost port specs....... did i screw my head up?
all numbers in inches
I used a .75 ball nosed end mill in a manual machining center we have at work
one port, .710 wide
1.725 long (.112 higher than the stock side ports)
raise the exhaust port .08
so what do you guys think?
Nashport_Native is offline   Reply With Quote
Old 03-28-2005   #2
well I took it for a spin today........I dont have a tach, and Im still running stock springs, so i would hold the brake and let the clutch get hot to let it slip more, and it still doesnt slip like I need it to......so im gonna have to wait untill my 1.5's from bat get here( thanks chris). but it does rev harder than it did.......think im gonna be limited by my stock reeds now though......
so far my mods are as follows,
9 fins removed from flywheel,
3 inches revmoved from header and added 3 to chamber
and now port work above.....
will give a better review tomrow when I take it to a big open area and let it rev till she revs no more......
Old 12-24-2005   #3
Re: my boost port numbers
i don,t think much of using a ball end tip when maching a cylinder port, it is wise to use a tree shaped tip as the flow will work much better.
RD RACING is offline   Reply With Quote
Old 12-24-2005   #4
Sorry, I’m in metric. Let me just convert your numbers...
one port, .710 wide
You used a 19mm Ballnose
Port = 18mm wide and is 2.8mm higher than the transfers.
And you raised the exhaust 2mm.
I think the exhaust will be much better now, regarding timing.
Boost port: the roof angle is ok if maybe a bit steep and the width is good, so shape wise its good.
BUT its duration if waaaay to long compared to the transfers. On this engine a 2 degree time (normal) difference in boost and transfer equates to about 0.4mm, so you’re way past that. Must have more like a 15 degree difference. The raised exhaust will help towards correcting the blowdown time though. It’s probably loosing a lot of good fresh mixture out the exhaust.
Really I’d say it has very bad flow characteristics now. You say it still works??
Mr_Cag is offline   Reply With Quote
Old 12-24-2005   #5
cagaroni's Avatar
so what #'s do you recommend for a good functioning boost port, i want to put one in before I re-assemble with my bbk/fcsc but I'm looking for some trusted #'s on the design of it.
Old 12-25-2005   #6
I can't give any tried and tested numbers as my engine is still a work in progress.
But make it the same height as the transfers, as wide as you can and still fit betweeen ring gaps of the piston, by 2mm into the cylinder wall - anymore and you risk breaking through.
And also put a window in the piston to get good flow up the port Joba good'n
Added a boost port tonight *pics* 42F67N Air Cooled Pocketbikes 105 1 Week Ago 04:53 PM
Four boost port BB head review LONG Dallas L7 Air Cooled Pocketbikes 25 05-24-2005 09:31 PM
My 2 Boost Ports ,Exhaust Port, and Piston Window Port!!! Day-Tone-A MX Air Cooled Pocketbikes 74 12-22-2004 12:21 AM
bb boost port and race piston question hackmunch Air Cooled Pocketbikes 18 11-01-2004 10:46 PM
Page generated in 0.24785 seconds with 34 queries
