Originally Posted by onedownfiveup Ok so I got my Cag two nights ago and 30 seconds after I got it running it finally shut off. It choked till it died. I took the fairings off and the crappy fuel line was bent. I was told to put a fuel filter on there too so I did and I also took apart the carb to clean it out. I put everything back together on the carb and the bike will not start. I figured it was just becsaue no gas was in it. I also broke the starter lol. Anyone have any suggestoins when I get my new starter. |
Did you shorten the fuel line when you added the filter? You want to take out the kinks. The best way to find out if fuel is in the carb is to remove the little
philips screw onder the bowl and if gas pours out your getting fuel also did you clean the petcock? The fuel switch.
