Old 02-02-2009   #1
Need Help
need help my pocket bike got trippel stage reeds,light weight flywheel ported carb and put a expantion on my exhuast pipe,if got good top end but my bike sucks on pull away WHAT can i do.Any help would be appreciated.
ignus is offline   Reply With Quote
Old 02-02-2009   #2
Re: Need Help
well first you might want to check if your running to lean or to rich because by porting your carb and with reeds your prolly going to have to rejet your carb. Second are you running a 40 cc or 49 cc cylinder? with tripple stage reeds I recommend a 49 cc to put out that low end power that the reeds will take away from low end since they are so stiff.
Imastudnotyou is offline   Reply With Quote
Old 02-04-2009   #3
Re: Need Help
shot for the replie,how would i know if im running to lean or to rich,if got a bm6a plug in it now and its burning like a grey color if also got a bm7a wich 1 is better,what can i do about my jet.
Old 02-04-2009   #4
Re: Need Help
im running a 49cc
Old 02-04-2009   #5
Re: Need Help
if its a REALLY dry, grey color, it could be too lean. I could be wrong on this, but with cars I know you just want a solid black color, no wetness and not a large amount of buildup.
sleeper832 is offline   Reply With Quote
Old 02-04-2009   #6
thestone11's Avatar
Re: Need Help
about plug color...the ideal will be a golden tan to dark brown. Remember for jetting...the main jet only controls throttle from 3/4 to wide open, anything lower than 3/4 throttle is the throttle needle.
What gearing are you using now? try to swap the front pinion gear to a smaller one or swap the rear sprockets to a bigger one for more low end power. I will swap the rear one, coz it is easier to work on. removing the front pinion gear is pain in the butt.
Old 02-04-2009   #7
MelloCag's Avatar
Re: Need Help
Grey or ghostly white is a no, no... Risk of Booom.. With cars soild black is not always good either it's a sign of running rich or using poor grade petrol.
Old 02-04-2009   #8
Re: Need Help
this is true. i'm always looking for a black in my cars considering they're forced induction. always rather be running heavy on fluid than running lean. I dunno about these little motors though, I would trust stone up there. In any case, I think we are all in agreement that the grey color you're getting is no good, and is most likely pointing to a lean fuel mixture.
Old 02-04-2009   #9
farmerguy's Avatar
Re: Need Help
get a jet pack and run with the .70 works good for me. maybe a little rich but better to change a plug than a piston and bore
farmerguy is offline   Reply With Quote
Old 02-04-2009   #10
Re: Need Help
getting my cagllari started
msthebadguy is offline   Reply With Quote
Old 02-06-2009   #11
Re: Need Help
how would i get my bike to burn like a golden tan to dark brown,would u sugest that i maybe ajust my needel
Old 02-06-2009   #12
Re: Need Help
what gearing would be good for bottom end
Old 02-06-2009   #13
farmerguy's Avatar
Re: Need Help
6/68 should be good
Old 02-07-2009   #14
javy_trkstr's Avatar
Re: Need Help
If possible I would suggest up jetting in slight increments, and slight decrease in the air intake perhaps, was this gray color from a new plug? A new plug is the best diagnostic on how your engine is doin.
javy_trkstr is offline   Reply With Quote
Old 02-07-2009   #15
Re: Need Help
yeay its a new plug a bm6a,i just used it at the last race i had,how would i decrease my in take and woulnd it effect my bike cuase i ported my carb
Old 02-07-2009   #16
Re: Need Help
would i still get a nice top end on it
Old 02-07-2009   #17
Re: Need Help
my gearig is 7/68,that is standart
Old 02-08-2009   #18
Re: Need Help
The air/idle screw can decrease/increase you air intake if you don't have jets, which I lost mine. If you ported your carb then that means your air/fuel intake is better and faster. This can be part of the reason why you should adjust your air/idle screw to fine tune it, this can help with your air/fuel mix proportions.. I'm not positive you need to up idle screw or down thats why you should try both.
Anyone know which way increases/decreases air/idle screw on the delrep with black bowl? I'm thinkin lefty opens n right closes but I should be wrong right?
Old 02-08-2009   #19
farmerguy's Avatar
Re: Need Help
turn right lifts the slide up
Old 02-09-2009   #20
Re: Need Help
aaahhhh, didn't know it moved the slide..
thnx
Page generated in 0.33028 seconds with 75 queries
