Old 10-04-2004   #1
moomoo's Avatar
Need help about tire change...
I have some problem with tire change. I put the tire in the rim already but the lip of tire does not attach the lip of rim. During filling the air, the air leak between tire and rim. It won't be full. What should I do?
moomoo is offline   Reply With Quote
Old 10-04-2004   #2
Enema Of The State
PaulPaulPaul's Avatar
Smile
I had the same problem with a wheelbarrow once, lol, I had to take it to a tire shop, and they used their high pressure hose to fill it. It moves a lot of air at a high rate, and POOF they got it. This might be easier for ya, and they didnt charge me. Good Luck.
PaulPaulPaul is offline   Reply With Quote
Old 10-04-2004   #3
moomoo's Avatar
Thanks a lot...
Old 10-04-2004   #4
Enema Of The State
No prob, if your in a REAL hurry to do this, you could use a tie down strap around the circumfrance of the tire, and then air it up, so the bead is close to the rim. Just try a few things, good luck!
Old 12-17-2004   #5
Post Need help about tire change...
I am at the same point today you were on October 4 (your post). I can't get the 'first' air into the tire because the rim/bead doesn't seal yet.
So what did you finally do?http://www.pocketbikeplanet.com/images/icons/icon5.gif
Sete is offline   Reply With Quote
Old 03-10-2005   #6
how do you get the tire off in the first place
crowntownpb is offline   Reply With Quote
Old 03-10-2005   #7
MotoXRyne
Posts: n/a
Smash the tire off the bead, then get some soapy water and put it on teh rim and the tire, then use two tire irons to pry it off. I have these and can get a tire off in probably less than a minute.
http://rockymountainmc.com/Product_D...v?pid=00017676
Old 03-10-2005   #8
woof's Avatar
I was able to do mine here at home with a small portable air compressor/battery jumper that got from Costco for about 70.00 ...Try taking out the valve core it will allow air to go into the tire faster and you may need to push on the tire a little where you hear it leaking from, to help it to stop leaking air at the beads. The most I went was 39-40 lbs. MAX. I wanted to be safe. Spray the sides with soapy water and that will help the tire seet evenly and correctly. You may need to let out the air and try it a few times to get it to seet just right. But I would be carefull and don't put too much air in it. Good Luck
I just noticed this was an old post that came up, Hopefully it will help somebody out anyways.
woof is offline   Reply With Quote
Old 03-10-2005   #9
old trick is to spray starting fluid in tire and flip a match close to it and it would pop it in place. very dangerous but effective. so be careful doing it.
DieHard is offline   Reply With Quote
Old 03-11-2005   #10
what psi do this tier ned i got sotck lucky 7 tiers?
itsays 2.5 atm not psi
Old 03-11-2005   #11
W W W. H A N G L O S. N L
Flashboarder's Avatar
2,5 atm = 36 psi
How much PSI for cag tires??
Flashboarder is offline   Reply With Quote
Old 03-11-2005   #12
thanks that was very help full
How-to change out your front pinion snowboardgeek1 Air Cooled Pocketbike How-To's 3 11-30-2009 09:04 PM
Changed Tire, now it won't hold air. Help!!! Punch It Air Cooled Pocketbikes 17 08-20-2005 03:56 PM
How to seat a tubeless tire AtomicBiker 2-Stroke Midbike How 2's 0 02-27-2005 01:18 AM
Any easy way of changing a tire? tnk7313 Air Cooled Pocketbikes 14 11-04-2004 03:13 PM
sprocket change for higher top end? tnk7313 Air Cooled Pocketbikes 7 09-22-2004 07:28 PM
Page generated in 0.25955 seconds with 51 queries
