Old 12-15-2004   #1
Angry New bike troubles
Hey
I just got my bike, and I dont think its sounding right. ALso when I release the brakes the rear wheel spins. I tighten where the throttle cable goes into the carb, and made sure the cable was tight on the throttle end, and it seemed to help a bit, but not much. Heres a vid of it in action: (right click and save target)
http://www.members.shaw.ca/countblah69/MVI_0008.AVI
T@NK is offline   Reply With Quote
Old 12-15-2004   #2
Club PBP Member
jman47cc's Avatar
sounds to me like you need to adjust the idle screw. It seems to be idling high.
Old 12-15-2004   #3
alright, i changed the idle and it seemed to work for about 20seconds then died. After that it wouldnt start. I changed the idlle back and forth makin little turns and some times it put's for about 2 seocnds then dies.
Old 12-15-2004   #4
Club PBP Member
jman47cc's Avatar
that means the idle is to low now, or at least sounds like it. Try turning it up more.
Old 12-16-2004   #5
how can i tell if i set the idle to high? would the bike still start?
Old 12-16-2004   #6
alright i got it working, but it still sounds bad, like its struggling to stay alive... should i lower the idle some more?
Old 12-16-2004   #7
badazztoyz.com's Avatar
put the bike up on a stand and put in the idle screw slowly until the wheel starts to spin then back it up about a quarter turn
Old 12-16-2004   #8
alright, i got the spining to stop, just turned the idle down a tiny bit still it stoped spinning, but it still sounds like its gonna die..
Old 12-16-2004   #9
SDPBRider's Avatar
Did you clean out the gas tank b4 you filled it up? Sounds like your carb is clogged and is fighting for gas to stay running...
Old 12-17-2004   #10
ya, i cleaned it
Old 12-17-2004   #11
Club PBP Member
jman47cc's Avatar
Well man you need to disassemble and find the problem. On these bikes theres not much it could be. Go over everything on the bike and check for debris.
When you first get your Cag Pocket bike! insyder Air Cooled Pocketbikes 19 06-27-2007 08:18 PM
Does the BT-Hydra AC from Badazz have suspension? Help finding new bike. Adam Connell Air Cooled Pocketbikes 7 04-27-2005 11:37 PM
How To: Building a bike stand AtomicBiker 2-Stroke Midbike How 2's 0 01-31-2005 01:23 AM
Airlock in carb? Fuel line? Bike starving for fuel? Muggy Chat 2 11-17-2004 12:15 PM
Page generated in 0.23923 seconds with 48 queries
