Old 11-26-2004   #1
davesmotors.com's Avatar
New Jet-Pro 'High Rev' Pipe - exclusively at DDM
Jet-pro has just released their new 'high rev' pipe for 47cc pocketbikes. In their testing, low and midrange power were improved from the original jetpro pipe, and top end was substantially improved.
Fits both half fairing and full fairing bikes. A version for the RSA bikes will be available in approx 1 week.
These pipes are available exclusively at DDM
http://www.davesmotors.com/store/product1480.html
davesmotors.com is offline   Reply With Quote
Old 11-26-2004   #2
Dave_O's Avatar
holy sh!t, i never thought this day would come. this sounds like a really good pipe. and i would not mind buying this at all.with the extra top end and imporoved low end and mig range this pipe would seriously kick a$$. is there any holiday specials on this? have a review on it?
Dave_O is offline   Reply With Quote
Old 11-26-2004   #3
Dave_O's Avatar
would you have to rejet? also how much top end does the ip2 give you compared to this pipe?
Old 11-26-2004   #4
geezer's Avatar
Do you have any pic of the pipe mounted? If the blue rubber washer mounts where the regular JetPro mounts it seems that the stinger would hang a mile out the back of the bike.
Don't get me wrong. If it was the best pipe I would still mount it and hang a red flag off of it!
geezer is offline   Reply With Quote
Old 11-26-2004   #5
Spud Warrior's Avatar
A mounted pic of it on a hf cag, ff cag, and a rsa cags would be really nice, but i only care about the rsa pic
Spud Warrior is offline   Reply With Quote
Old 11-26-2004   #6
avangusva's Avatar
If you send me one half price ill test it for you.
avangusva is offline   Reply With Quote
Old 11-26-2004   #7
M J D's Avatar
now they tell us after i have just fitted one of the normal jet pros
Martin
M J D is offline   Reply With Quote
Old 11-26-2004   #8
geezer's Avatar
Martin
Same here, bought into a new fad too soon again. Not that the original JetPro pipe I have is bad or anything. I just bought when the only two "real" choices were the JetPro or IP2. Oh well, anayway it seems like some fellas are getting good results from modding the stock pipe. I think that will be my route from now on. I mean for the price of outfitting a couple of bikes a small wire feed welder could be purchased. and when the pipe mods are done you can still weld other stuff.
Old 11-26-2004   #9
hey geezer dont be fooled by what people are saying about stock pipe mods! a friend and i have done plenty of stock pipe mods and it wont even come close to ip2 rpms! as for jetpro i have no idea if modded stock pipe can hang with it but i guess someone on here has there review of it!
Old 11-26-2004   #10
Ritchey79's Avatar
The new Jetpro High Rev is a great looking pipe and from looking at the design it will do just as it says. As for modding the stock pipe you can mod the pipe to produce what ever results you are after by knowing how to engineer a 2-stroke pipe and moddifying the dimensions of the pipe accordingly. The problem with this is the pipe will never be of as high of quality construction as one of the aftermarket pipes you can purchase b/c the lack quality of metal used in the stock pipe. The IP2, PBU and the Jetpro are engineered very well and you will be pleased with either of them. As far as performance any pipe "could" be moddified to outperform another pipe, but these aftermarket pipes have already been engineered for optimal all-around performance, modding the stock pipe is just a cheaper alternative.
Old 11-26-2004   #11
what richey is saying is take the p.o.s. stock pipe (that is about .05mm thick) buy a welder and some tin and make it to the same specs as ip2 and bam your modded stock pipe is as fast as ip2 pipe or the jetpro! this debate about modded stock pipe is like beating a dead horse, you can kick it all day long but the **** thing is still dead! good luck and have fun
Old 11-26-2004   #12
Ritchey79's Avatar
That's not even close to what I'm saying! You could never "COPY" the dimensions of the IP2 and mod you stock pipe and expect it to perform the same. You need to engineer the stock pipe to perform how you want it to perform. You can't just cut and slap on some tin can and weld it just to make the chamber bigger "hack" it together and expect it out perform the IP2. Well you could but you probably have a name like "hack"munch. You need to decide how you want the bike to perform, consider your mods, and run a gauntlent of forumlae to calculate the correct dimensions of moddification for your pipe. This has been done numerous times by people who understand the construction of a 2-stroke pipe. If you read the posts about modding the stock pipe it will clearly state that of the calculations performed and the trial and error tests, the dimensions that have made the most improvement are the ones that have been posted time and time again. The construction of a 2-stroke pipe is a science, it cannot be "hacked" together as "hackmucnh" has stated. However since we have done the dirty work for you and provided the best dimensions for an "all-around" performing pipe, all that is left to do is cut and weld your pipe according to those dimensions. That pipe will not provide more rpms than and IP2 b/c it's not designed to. It will provide more power than IP2 or stock and more rpms than a standard jetpro. Giving you a great all around pipe for the cost of the wire in your welder. It however, as stated time and time agian will not be made of high quality material as the aftermarket pipes. It won't last as long as an aftermarket pipe. It will need to be reinforced with an additonal mounting bracket for the silencer to prevent the pipe from cracking. Also the stock pipe off a L7 cag is far supeior to that off the other FF & HF cags and that is the only stock pipe I recomend moddifying!
You guys that want to mod your pipe, go ahead and try it, don't be discouraged by people that can't weld or have had bad success due to lack of knowledge on 2-stroke design like this guy. It will perform all-around. It won't be high quality. It won't beat the IP2 in rpms. It will save you money. You will have fun experimenting. And you will have bragging rights when you're done. For those of you who don't want to then I highly reccomend the after market pipes, I have a jetpro and an IP2 myself and am very happy with them both. They perform great for there intended applicaton. However, I race 2 different modded stock pipes depending on track conditions!
If you wish to mod your pipe to outperform an IP2 it is possible and the dimesions of the pipe will in absolutely no way at all resemble the IP2 pipe, the stock pipe or the modded stock pipe. This pipe has been designed on a profesional 2-stroke pipe engineering program, by proffesional automotive/mechanical P.E. engineers working for a proffesional 2-stoke manufacturing company that I am not at liberty to disclose. It has been engineered for optimal wave refraction utilizing the header tube and divergent cone from the stock pipe. This is a highly modded stock pipe and it will KILL an IP2 pipe in power and topend! Below is a pic of this pipe sitting next to a stock pipe.
Hackmunch don't be jealous b/c you don't have this ... LOL!
Old 11-26-2004   #13
Cdshee's Avatar
This seems like a great pipe .. but as usual ... they don't fit the "Lucky 7" bikes ... yet ...
Cdshee is offline   Reply With Quote
Old 11-26-2004   #14
well well well i see we have a guy that is a little salty about some comments made about him! just watch what you wish for richey you will see me sooner or later on the track and you'll be eating your words! ( hmm columbus ohio about 100miles south of me) ok (mister i think i know everthing)lets see you put your money where your mouth is and lets race !! ill be looking for ya in the spring! i can back up the smack i'm talkn can you?
Old 11-26-2004   #15
Ritchey79's Avatar
LOL... LMAO! Bring it!
By the way anyone interested in seeing the IP2 Killer in action, please come out to the JMAX indoor race tomorrow in Newark, Ohio. See ya there hackmunch.
Old 11-26-2004   #16
Dave_O's Avatar
will this pipe have low end like a bbk and top end ip2? i might get this pipe, or a boost ported bbk and ip2, im ordin my stuff to night and if i can get the same performance with that setup and this pipe i want the pipe. post asap
Old 11-26-2004   #17
badazztoyz.com's Avatar
I like my old bike with the 39cc jug and the ip2 pipe cause it reved higher, although after i put on the bbk i put the squish to .5 and when i raised it the pipe loved it cause it could rev higher...pm me dave and well build you a killer setup
Old 11-26-2004   #18
Dave_O's Avatar
lets do it!! cheack your pms so you can im me some time
Old 11-26-2004   #19
Fear not, only a few days to wait
Old 11-29-2004   #20
Sydeshow MO's Avatar
$169. is crazy. I paid $140 for my original pipe and found out after testing other pipes with my mods that the Fatty is the best bang for the buck to date!!! The Jetpro just didnt let my motor rev high enough.
Im not knockin the new design cause I have seen it perform yet. Looks like they open the expansion chamber abit to allow higher revs. Hope it performs well. I liked my Jetpro when I first got it. I guess you can say I out grew it.
R6 (not the Yamaha looking one) 4 Stroke Question AaronLucia 4Stroke Midbikes 27 07-14-2009 09:59 PM
Jet Pro Fatty Pipe for 47cc Cag 416RACER Air Cooled Pocketbikes 5 04-02-2007 09:17 AM
Top pipe shootout Outlaw50 2Stroke Midbikes 48 02-08-2006 05:21 PM
JetPro vs. IP2 (a first hand comparison) Vol. 2.0 eldevioso Air Cooled Pocketbikes 22 04-23-2005 01:15 PM
Jet Pro High Rev Pipes now online DemonSpit Air Cooled Pocketbikes 0 12-10-2004 07:52 PM
Page generated in 0.40437 seconds with 77 queries
