Old 12-28-2004   #1
Question new problem with my boys cag
hey all well after reading the forum AFTER i got his up and running i saw i missed some key thingsd to do BEFORE you put gas in and go for a ride. well got the starting and running problem fixed, now here is one that is making me scratch me head, after putting carb back on and such i had him take it for a spin today well its running great and fast as he is 11 and weighs 50lbs hehehehe but now when he turns right it goes full throttle in the turn he hit the ground hard(good thing he got his pads and helmet for x-mas) lol anyway when its on the stand you turn the wheel to the right and it goes wot i was going to play around with the cable but b-4 i start messing around i want to make sure this is the route to go can it be too tight loose and in a turn it tightens up or what? any help would be great. thanks in advance
minircrx is offline   Reply With Quote
Old 12-28-2004   #2
andrewdn's Avatar
Cable too tight
My bike had the same problem. Firstly I cut the cable tie that holds all the cables together in the front by the fairing bracket. Secondly, give the cable a little slack buy adjusting it at the throttle or the carb. Release the lock nut and turn the grommet in a few turns.
andrewdn is offline   Reply With Quote
Old 12-28-2004   #3
wot in turns
thanks for the reply cable ties are cut ill try the adjustments next and let you know
Old 12-28-2004   #4
andrewdn's Avatar
You should have some play at your throttle.
Old 12-28-2004   #5
Thumbs up problem solved
thanks found the problem thought i had used a cable tie on the fuel line it was on the throttle cable cut it and no longer doing the wot while turning right i had it tied to the frame causing it to bind i guess thanks
Old 12-28-2004   #6
geezer's Avatar
Good job with the protective gear!!! But I don't have to tell you that. Because good parents would not have it any other way.
geezer is offline   Reply With Quote
How-To's - Cag performance tips and tricks snowboardgeek1 Air Cooled Pocketbike How-To's 1 05-30-2008 02:18 PM
Problem with my Cag, need some help zer0 Air Cooled Pocketbikes 0 03-16-2005 05:54 PM
Brand New 47cc Cag Idle Problem joshiestevens Air Cooled Pocketbikes 67 11-28-2004 02:08 PM
another cag problem crusher Chat 1 11-09-2004 12:38 AM
My Cag won't start (Carb Clog Problem) onedownfiveup Air Cooled Pocketbikes 14 09-24-2004 01:27 AM
Page generated in 0.22770 seconds with 33 queries
