Old 04-05-2005   #81
PBU has a kit that they just got out with:
http://www.pocketbikesunlimited.com/images/NOS.jpg
npereira is offline   Reply With Quote
Old 04-05-2005   #82
OBSIDIAN's Avatar
Wink
Do you need a battery for this kit? Where would you mount that? I hardly have enough room now.
OBSIDIAN is offline   Reply With Quote
Old 04-05-2005   #83
Mirakle's Avatar
thats what i was gona say.....n where is the price?
Mirakle is offline   Reply With Quote
Old 04-05-2005   #84
This is a Nitrous Express Piranha kit. Its a wet n2o system (gas+nitrous exiting from the nozzle) Cheaper piranha kits are about 500USD. These kits are not for 47cc
This kit needs a 12v power supply for the relay and the solenoids. You can take 12v from 2 9v batteries using a 7812 regulator but it isnt a good kit for 47cc
Also steel lines are hard to route through a 47cc
Dry kits are more simple, and some of them can be powered from 9v batteries like NOS sneeky pete kits. these are about usd200
DANO is offline   Reply With Quote
Old 04-05-2005   #85
Mirakle's Avatar
hmmmm.....it said not for 47cc? ill have to check it out, maybe when i get that X7R1 i want. which my b a while
Old 04-05-2005   #86
you can use in a 47cc, but you will have the power supply problem. a smaller kit is better for these bikes
Old 04-05-2005   #87
Mirakle's Avatar
yea......that bottle on that kit is HUGE
Old 04-06-2005   #88
how much does the PBU kit cost?
thanx for ur help
60m.p.h.mini is offline   Reply With Quote
Old 04-06-2005   #89
Mirakle's Avatar
uhh i think its lik 100-200 dollars
Old 04-07-2005   #90
gurt's Avatar
Originally Posted by OBSIDIAN
I've been running the whippet NOS for a few weeks now and it really works, too well. It does a wheelie everytime and two weeks ago it knocked me on my *** after the bike went vertical going end over end down the track leaving a nice trail of gas for me to slide on. I've since bought knee and elbow pads, I know I should have had them earlier, luckily I had a helmet and leathers on. I also installed a pressure regulator and gauge on the line. Now I run it at 1/4 of what it originally was which is now between 15-20psi. Last weekend I dragged another bike, I had him out of the whole and half way down the track he passed me and I hit the nitrous and flew by him finishing first. I don't know if it will ruin the engine but they aren't that spendy anyways so it's probably the only time in my life I'll be able to, "hit the NOS". I also don't know how safe it is, I'm sure something could go wrong but, we don't ride pocket rockets because they're "safe" do we?
do you have a video of this? on my bike it just makes it over rev and crap out.
gurt is offline   Reply With Quote
Old 04-07-2005   #91
OBSIDIAN's Avatar
Originally Posted by gurt
do you have a Video of this? on my bike it just makes it over rev and crap out.
Yea, I got video but the camera zooms out right before I hit it and the bike launches. I've use 5 or 6 bottles so far. We'll be taking more this weekend but I really need to find a way to hook it to the computer, my old RCA/USB adapter isn't compatible with WinXP.
Old 04-07-2005   #92
Mirakle's Avatar
yea i wana c nitrous in action
Old 04-10-2005   #93
crazy_ndn's Avatar
NOS Kit
is this dry setup kit worth buying its like $85 dollers (can $)....they say its good for 2 or 3 shots...but its hard on the engine?...http://www.pocketracerstop.com/parts...ce/nos_kit.jpg
crazy_ndn is offline   Reply With Quote
Old 04-10-2005   #94
Vbfinest's Avatar
it looks like co2
Vbfinest is offline   Reply With Quote
Old 04-10-2005   #95
pyro_incubis's Avatar
Originally Posted by Vbfinest
it looks like co2
ya i seen them on ebay also I thought the same thing co2 cartridges!
pyro_incubis is offline   Reply With Quote
Old 04-10-2005   #96
You can go to a mountain bike shop and get a CO2 inflator for bike tires and then go to a place like save-on foods or superstore and get a pack of like 10 nitrous whippets called cream chargers. there for making whipped cream with, you will find them in the untencil isles were the spatulas are.
then go to like a pluming shop and get some fittings. wont cost more than 50$ to make the kit.
be sure not to get soda cargers because they are co2 not nitrous oxide like cream chargers
PS its not called NOS its called nitrous oxide. NOS is a company name that blelongs to holley.
IMO it probly wont work. when you buy nitrous oxide kits like ZEX or Venom your paying alot for the delivery systems and stuff like that
636andy636 is offline   Reply With Quote
Old 04-10-2005   #97
OBSIDIAN's Avatar
It does work, I run it. I posted this a few times, do a search and you'll probly find it.
Old 04-10-2005   #98
how to make the nos kit
you can got to your local bike shop and get a co2 tire inflater for $20.00 or less depends what brand but shop around adn you can find them cheaper. and then go to your local harware store and get 1\4 o.d line depends on what type of bike or chopper your going put it on you will need about 5-6 feet or line its like 0.07-0.14 cents per feet and you will need to get copper fittings take the co2 inflater to the hardware store with you to find the right fittings you will all so need to get some washers 7-8 washers belive its 8 washers to put in side the inflater so that the nitrous bottles will be high enought to reach the top. this set up is not hard to make it will cost you less to make it your self then to but it from someone els adn you can get the whip chream chargers from e bay dirt cheap just type in whipp cream chargers and it will take you to all the chargers.
parts you will need:
co2 inflater(local sports shop,bike shop should not cost more then 20 bucks)
7-8 washers(glue the washers to each other and to the base of the inflater)
5-6 feet of 1\4 od line (reg water line will work like for the ice makers cost 7-14 cents per feet)
copper pressure fittings you will need about 2 of them one that gos to your intake should be 1\4od fitting and the other should be 1\8taping out to a 1\4 fitting (but not sure its been a while since i made one of these kits so take your co2 inflater with you, you can find the parts better at osh $6.00 for both fittings)
for a better fit it is better to grind out the in side where the cartridge pill get poked at this will help the cartridgefrom getting stuck when taking it out by not doing this you will see what im talking about. good luck build at your own risk
integls594 is offline   Reply With Quote
Old 04-11-2005   #99
crazy_ndn's Avatar
k well thanks for all the help.... i might make the kit or just buy it i dont know yet but to make it sounds pretty simple...
Old 04-11-2005   #100
LOL all that ****ing around I think its may be better for you to buy the kit..Unless you live close to the hardware store and the bike store
Does it even help and are you useing it at topspeed?
Top pipe shootout Outlaw50 2Stroke Midbikes 48 02-08-2006 05:21 PM
possible cheap nos kit? Pegleg364 2Stroke Midbikes 6 08-16-2005 03:33 PM
Does the BT-Hydra AC from Badazz have suspension? Help finding new bike. Adam Connell Air Cooled Pocketbikes 7 04-27-2005 11:37 PM
My Bike Ryno Asia Pacific 18 03-11-2005 08:07 AM
MPBClub Mini-Motard/Pocket Bike Summer Racing! moto-x-troy Midwest 0 01-25-2005 02:17 PM
Page generated in 0.38693 seconds with 77 queries
