Old 11-30-2004   #1
1.8TurboS's Avatar
PBU Sleeper BBK and Wlboro HP carb...thoughts?
Hey guys, I'm about to order the PBU Sleeper BBK and the Walboro HP carb kit. I was just wondering if you had any different suggestions before I order this combo this afternoon. I was gonna get the Dellorto 14/14 with the 2.5 manifold, but it's too much money. 7 tooth pinion will also be on the way Thanks for you help.
PBU SLEEPER HEAD KIT
PBU NOW OFFERS A NEW HEAD KIT FOR YOU GUYS THAT WANT
THE STOCK LOOK WITH THE ADDED POWER AND ACCELERATION
THAT YOU HAVE COME TO EXPECT FROM
POCKET BIKES UNLIMITED
THIS KIT WILL WAKE UP YOUR MOTOR BEYOND YOUR
EXPECTATIONS, THOSE OF YOU WHO HAVE INSTALLED IT WELL
KNOW WITH THE ADDED TRANSFER DESIGN AND MATCHED
PISTON SET, THE SLEEPER HEAD KIT IS A BARGAIN.
INCLUDES EVERYTHING NEEDED TO BRING YOUR 47cc OR 49cc
BIKE INTO A TOP END RACER.
ADDS APPROXIMATELY 16 MPH OVER STOCK
DUAL TRANSFER 49cc BORED CYLINDER HEAD
BOOST PORTED & SKIRTED 49cc PISTON
.004 SHAVED RACE RING SET
EXHAUST AND BASE GASKET
NGK SPARK PLUG
AS A BONUS WE HAVE ALSO INCLUDED OUR WRIST PIN & AND
BEARING SET AT NO ADDITIONAL CHARGE.
....and
ADA Racing Hi-Performance WYK carburetor kit with 3D machined aluminum manifold for optimum flow. Kit includes Walbro 15mm WYK carb, velocity stack, billet aluminum manifold, and all hardware and gaskets. Carb features high and low speed tuning screws. Fits 40 and 47 cc pocketbike engines.
1.8TurboS is offline   Reply With Quote
Old 11-30-2004   #2
caferacer's Avatar
I would subsitute the Proline reed valve w/race carb for the Walbro WYK set-up.
JMO
Old 11-30-2004   #3
1.8TurboS's Avatar
Most importantly...How much is it?
Old 11-30-2004   #4
caferacer's Avatar
PM Kirk @ Proline.....
Old 11-30-2004   #5
1.8TurboS's Avatar
Thank you much cheers.
Old 11-30-2004   #6
yeah i would stay away from the walbro carbs, you need more than the 15mm one you described for a bbk anyway, i used a 17mm walbro but its just not right, i had better success with a highly modified stock carb or best bet would be a 14/14 or the proline setup
loopedout36 is offline   Reply With Quote
Old 11-30-2004   #7
Ritchey79's Avatar
Lets put it this way... NONE of the euro bikes run a butterfly carb like the Walbros and some of them make 15-20hp! They all use slide carbs like the stock one on cags. Also most of the euro bikes run a reed setup similar to Proline's. The stock carb when ported can flow alot of cfm. The only real restriction in the stock cag intake is the reeds. They only allow for 35cfm of flow into the engine. This is horrible! I think the Proline kit flows around 80-100cfm! The math is simple, more air+gas= POWER!
Old 11-30-2004   #8
badazztoyz.com's Avatar
well said ritchey. Ive tried to tell people the walbros are meant for a chainsaw or weedeater. The stock carb can be ported to 14.5 but we have a 15mm coming out which will flow enough for our 4 petal reed cage our prolines.
Old 11-30-2004   #9
caferacer's Avatar
The Walbro 'race' carb that Proline sells with their reed valve kit made me a happy camper.
Old 11-30-2004   #10
yea i have turned some really high rpms with proline reed box and 19mm walbro carb i would have to beg to differ on which type of carb is best but i am sick of everyone bitc#n on here when they have not even tried other equipment but there own! good luck and have fun
Old 11-30-2004   #11
snowboardgeek1's Avatar
Walbro carbs are actually pretty **** good. I have one. Its a ***** to tune at first, but once you get a hang of the tuning process, you'll begin to think why the italian bikes wont use it. You never have to worry about swapping out jets. Its all about tuning.
Old 11-30-2004   #12
see snowboard has went to the darkside!!!! no turning back now!!
Old 11-30-2004   #13
Boogie-Moto's Avatar
What "number" HP carb do you get with the Pro-Line or PSWS reed kit. I just installed the Walbro 668 on my cag and am having a hard time tuning.
Looking to get the reed kit and for the extra 30 bucks should a get the hp carb that comes with the kit?
Boogie-Moto is offline   Reply With Quote
Old 11-30-2004   #14
I wouldn't go that far hahaha. I still think dellorto's are the best out there. Any 14mm carb that's used on 10HP motors has to be good.
Old 11-30-2004   #15
ive ran all types of walbros and others and ive found that the walbros flow good at wot but nowhere else. the stock carbs work well when modified and nothing really beats a dell orto that ive found
Old 11-30-2004   #16
caferacer's Avatar
I tried my 668 when I first installed the reed kit and could not get the high end tuned correctly.Just seemed like I couldn't get enough fuel on the top.
Installed the Walbro that came with the kit and had it tuned in 30 minutes.
And yes...I do know how to tune the Walbro carbs.I have owned the 668 and the 603.
You can always try the 668 and if it doesn't get you where you want to be then get the carb that comes with the kit.
Good luck!!
Old 11-30-2004   #17
Good luck!!
Thanks.
What is the difference between PSWS kit and ProLine Kit besides $29.00 and the carb being tapped for the Pulse Line?
Old 12-01-2004   #18
caferacer's Avatar
Thanks.
Proline's price includes shipping and the carb already tapped.
I'm not sure if you get the same ordering from psws.
Old 12-14-2004   #19
x7headstrong's Avatar
I Have Pbu Mods Spend About $750.00 Its Not Good (headstrong Kit ,pipe,adjustable Filter,dual Boostube,carb)i Recomend Go To Proline Way Cheaper.
x7headstrong is offline   Reply With Quote
Old 12-14-2004   #20
caferacer's Avatar
Angry
Page generated in 0.36549 seconds with 74 queries
