Old 10-27-2004   #1
amanthebest's Avatar
Pocket bike noob....Help or tips please?
It's a Rossini bike....
I have heard it is a non reliable and crappy bike...but please dont say get a new bike or any of that stuff...just give me tips on how i can make my bike BETTER or how to take best care of it..
Do you guys have any tips on things I SHOULD WATCH OUT FOR? FOR being worn out or breaking ETC?
Please let me know....
thank you!!!
amanthebest is offline   Reply With Quote
Old 10-28-2004   #2
Obpr's Avatar
Obpr is offline   Reply With Quote
Old 10-29-2004   #3
POCKETMASTER's Avatar
I do not have any personal experience with the rossini bikes, however after reading most of the posts involving them they seem to be the same as all of the other cags. the rossini bikes are supposed to have a bigger engine though. the best recomends I can give are to replace ALL of the screws,nuts, and bolts. all of the ones that come on the cags are junk. put blue loc-tite on all fasteners. keep it clean. make sure the chain has proper tention(about 1/4 inch) and make sure that the chain alignment is straight. if it is not it will cause many problems like broken pinions, rear wheel drag, and broken chains to name a few. wheel bearings the biggest a problem I have seen on this site. replace them with aftermarket ones as soon as possible. use a good quality 2 stroke oil, it wont make a difference in how it runs, just how long replace the sparkplug about every 10 tankfuls, it will help keep the power up as the engine wears. I highly recomend getting the strongest clutch springs you can find, they help with taking off from a stop. carbon fiber reeds help a lot too. they perform about the same as fiberglass but they last longer.
hope this helps for a start. if you want or need more help, feel free to pm me
POCKETMASTER is offline   Reply With Quote
Old 08-10-2005   #4
you could put some aluminum tape around, where ever the pipe is close to the plastic sa you from replacing your plastic if it melts through. But it may not happen. safe then sorry.
ezrider is offline   Reply With Quote
Old 08-10-2005   #5
tblumer's Avatar
get better wheel bearings too, stock ones are junk
Old 08-10-2005   #6
Hyperacme's Avatar
This ones worth a read also...
Pinion & sprocket aligment
Hyperacme is offline   Reply With Quote
Old 08-11-2005   #7
JDQuikSIR's Avatar
I have a rossini, and I would have to say that the quality is pretty cheap. The whole fact is, I got it for a good price and wanted to see how much farther I can go with it. So I bought a 44mm head kit and port & polished my carb, got some fibreglass reeds, and a aftermarket pipe...( had to do some modifications since the inner part of the frame is really narrow....) also lightened the clutch and got stronger springs.
Good idea to replace fuel line with something high quality and a high flow fuel filter. Take all engine bolts off and replace with something stronger in strength and use loctite too. If you do a head kit, get a jet kit so you can add more fuel to the mix.
The bike is very different and doesn't even sound the same. I do find it sometimes the front end to lift up, but it still keeps straight.
Maintenance is key...and fuelil mixture. It's a good bike to start with...and has some potential...as long as you don't abuse it. I ran nitrous with the stock 47cc that it came with, and when the head swap was done, the piston was just fried. haha...still ran strong though...
JDQuikSIR is offline   Reply With Quote
Honolulu Meet? rossi808 Southwest 33 05-20-2009 07:25 AM
When you first get your Cag Pocket bike! insyder Air Cooled Pocketbikes 19 06-27-2007 09:18 PM
What is the 'super' in super pocket bike? nheaps Chat 12 06-05-2005 02:25 PM
Pocket bike engine won't stay running. amanthebest Air Cooled Pocketbikes 12 01-30-2005 02:58 AM
Darn! my pocket bike shipment is slow!! Patrick8 Chat 4 09-27-2004 09:47 PM
Page generated in 0.23396 seconds with 36 queries
