Old 10-02-2004   #1
Porting help
I just ripped off the barrel off my full fairing cag. I measured the bore and stroke, 44mm x 33mm and figured it's 49cc. Now my question is on porting the transfer ports. From the majority of the threads I have read porting looks like it has been done on mainly 39.6cc motors. By the looks of my barrel there doesn't look like there's much meat to massage. How far down the transfer ports do you port. I have marked out 3mm on the flater side of the tranfer port to widen but looks like I can only carry this down only about 7mm. If I go any further down i'll probably blow through. Even if I do all this work, does'nt the crankcase also need work. If a sandwich the barrel on top of the existing crankcase port it will defeat the purpose of porting, as it is going to be smaller. Does all of this sound correct if not I need some guidance.
redbackalarms is offline   Reply With Quote
Old 10-02-2004   #2
snowboardgeek1's Avatar
Looks like your head is a big bore head. Since you said you measured the bore and stroke and it came out to 49cc (its actually 48.3cc to be exact), I would definitely say you have a big bore head that came stock with your engine. Congrats.
Port the side opposite of what you listed. Actually, I wouldn't port the big bore head anyhow. The ports is big enough. If you put an IP2 pipe and CF reeds, you'll get about 12.2-12.4K rpms without even doing any porting on that head. AND that's also with a stock carb rejetted with a dellorto jet. This is a setup I have on one of my cags. Its reliable, pretty much bulletproof, starts on the first pull, and has a lot of low end torque with great top end speed.
Old 01-19-2006   #3
Re: Porting help
44mm bore x 33mm stroke = 50.17cc
44mm bore x 32mm stroke = 48.65cc
RD RACING is offline   Reply With Quote
Old 01-21-2006   #4
Re: Porting help
Radius of bore (22) squared... = 484
pi...(lets just go with 3.14)... x bore radius squared (484) = 1519.76
area of bore (1519.76) x stroke (32) =48632.32
48632.32 / 1000 = 48.63232 cc
Yay!... We dug up a two year old thread for this......?
borednstroked is offline   Reply With Quote
porting advice please jas328sport Air Cooled Pocketbikes 6 11-18-2005 08:47 AM
Porting the head flaminr6 2Stroke Midbikes 43 04-18-2005 04:56 PM
porting for reed kit? dadyfatsacs25 2Stroke Midbikes 2 03-04-2005 12:19 PM
"Follow up" on porting question / sort off nastro34 Air Cooled Pocketbikes 0 10-06-2004 04:15 PM
Porting and tuning? nastro34 Air Cooled Pocketbikes 21 10-01-2004 10:23 PM
Page generated in 0.17092 seconds with 28 queries
