When i first broke the engine on this specific Tai Chi i tried just to see if it was even possible to camfer the edges of the ports with any type of tool (the cylinder was shot anyway). I tried with the smallest add-on for a dremel. But there was no way you could reach inside. I also tried with finegrit sandpaper and a camfer tool, but it's was also too hard to reach down. I read a thread here how to do it, you will need a tool similar to a dentist drill. Very small and angeled at 90 degrees - you will also have to be very carefull due to the least amout of sliperage and you busted your cylinder for good.
I read in some old thread here that badazztoyz was selling a cylinders for the A/C C1 engines that has the ports fixed. So check with him before reinventing the wheel - it's more trouble than it's worth unless you have the right tools for the job. Or if you bribe a dentist to use his equipment
Mike
