Old 08-03-2005   #1
LuckyTuc7's Avatar
Angry Problem with my cag?
I'm having problems with my cag. It won't start and if it does you have to hold the throttle down at all times or else it shuts off. And I think my chain is giggly and loose. Does anybody know how to fix this or know what's going on> I'm so mad right now because now I can't ride it anymore till I can get someone to fix it or tell me wat's wrong. Someone PLEASEEEEEEEEE help me!!!
p.s. When you sit on it and it's on but your not going it goes off then too!! Please someone help me thanks!
Thanks
LuckyTuc7 is offline   Reply With Quote
Old 08-03-2005   #2
caferacer's Avatar
Did this cutting out problem just arise?
You may try turning you idle screw clockwise a tad until it idles on it's own.
As far as your chain is concerned you need to loosen the adjusters and the axle bolt and readjust your chain tension.
Old 08-03-2005   #3
LuckyTuc7's Avatar
Unhappy
Thanks but I'm new at this stuff and I just got the bike and thats why i'm sooo mad!! So can u explain more on how to adjust the idle clokwise and how to titen the chain and some other things that need to be done that I didn't mention. But thanks alot and please reply back as soon as u can.
Thanks,
Brian
Old 08-03-2005   #4
LuckyTuc7's Avatar
Unhappy
me and my dad think it's the clutch does anyone know if you can adjust the clutch or something. Please tell me I think it's the clutch so can u adjust it or do u have to buy a knew one or some other idea. Someone help and please reply if you know!!
Thanks
Old 08-03-2005   #5
LuCkYtEx's Avatar
Thumbs down
hey brian
when you get back tell me
PC
*Nick*
LuCkYtEx is offline   Reply With Quote
Old 08-03-2005   #6
hmmm... happened to me once, but check for a brokin cluch spring
eyeball is offline   Reply With Quote
Old 08-03-2005   #7
LuckyTuc7's Avatar
i don't get wat ur sayin
Old 08-04-2005   #8
If you think it is the clutch, maybe you have a broken spring in the clutch. If it is a clutch spring broken and the bike is on the stand and running, the back wheel will turn continuously, even at idle speed because the clutch is partly engaging. If the back wheel doesn't turn when idling on stand, then it isnt the clutch. As for the chain, loosen the bolt on the back wheel and adjust the tensioners until you have about 10mm play in chain. Then tighten back bolt back up and do up tensioners after tightening rear bolt. Also lube well. As for the being hard to start, there are many possibilities from oil mix, spark plug and gap, flooding. These are things you will have to eliminate one by one. Regards
Coaster is offline   Reply With Quote
Old 08-04-2005   #9
LuckyTuc7's Avatar
Red face
thanks for your reply and I will keep that in mind!!
Old 08-04-2005   #10
canadian mike's Avatar
clean the carb, clean the jet out. Do you have a fuel filter?
to adjust the chain loosen the axle, turn the 10mm adjusters sticking out the back of the frame until the chain is right (not too tight). You also want to make sure the sprocket is straight and parallel to the chain. Finish by tightening the axle.
canadian mike is offline   Reply With Quote
Problem with my CAG, yes me too. kifaru Air Cooled Pocketbikes 29 04-25-2006 11:04 AM
47cc Cag Engine Problem PlAyBoY69 Air Cooled Pocketbikes 5 08-04-2005 02:19 AM
new problem with my boys cag minircrx Air Cooled Pocketbikes 5 12-28-2004 07:41 PM
Brand New 47cc Cag Idle Problem joshiestevens Air Cooled Pocketbikes 67 11-28-2004 03:08 PM
My Cag won't start (Carb Clog Problem) onedownfiveup Air Cooled Pocketbikes 14 09-24-2004 02:27 AM
Page generated in 0.24959 seconds with 46 queries
