Old 10-05-2004   #1
Ride Like You Stole It's Avatar
Pull Start Locks with Spark Plug Installed - HELP!
Ok, so I installed my new spark plug after doing my run through of installing new mods on my cag. I go to pull the pull starter to test it and it seems VERY HARD. It locks up at about half a pull yet if you pull very slowly it will pull somewhat easy.
I took off the spark plug and then tried to pull it again and it pulled perfect, as easy as it was when I first got it. So I put the stock plug back on and it does the same thing as with my HP plug.
Basically its impossible to pull start with a plug installed and easy without a plug installed yet of course the engine wont start without a plug.
Anyone know what to do?
Ride Like You Stole It is offline   Reply With Quote
Old 10-05-2004   #2
insyder's Avatar
What mods did you do?
insyder is offline   Reply With Quote
Old 10-05-2004   #3
IP2 Exhaust with rewelded silencer, 3mm reed spacer, ada billet filter, cf reeds, and triple tappered needle at the 3rd setting
Old 10-05-2004   #4
djrice69's Avatar
compression from the piston and head its normal to do that wit the plugs on but when off it blows air out. give it sum more oil and prime it
djrice69 is offline   Reply With Quote
Old 10-05-2004   #5
Originally Posted by djrice69
compression?
Of course it's compression but with the few mods I made how would it triple the compression almost? It feels around 8 times harder to start. I can only pull the cord out 1/4 of the way before the bike jumps with it.
Old 10-05-2004   #6
djrice69's Avatar
wats ur gas/oil mixture?
Old 10-05-2004   #7
eaterofdog's Avatar
Check plug
Is your plug longer than the old one? The piston may be topping out on it.
Old 10-05-2004   #8
Start backing the plug out until the motor turns over. Is the new plug the same exact model as the old one? I bet that you may be running the wrong plug by mistake.
madpocketbike.com is offline   Reply With Quote
Old 10-05-2004   #9
djrice69's Avatar
he did put back his stock plug mayb the stock plug is fouled
Old 10-05-2004   #10
Club PBP Member
B G Motorsports's Avatar
Check your cf reeds and spacer.Maybe something is cocked and not leting you reeds to work right.or the reeds are too big not leting them move.
B G Motorsports is offline   Reply With Quote
Old 10-05-2004   #11
Sydeshow MO's Avatar
Only 2 things causeing this... Either your pluyg is too long and is hitting the top of your piston, or its just a matter of really high compression.
The only time I have seen compression so high that the pull starter was hard as hell to pull was on a Cag that had a TS head (Trevor Sellers) with adjustable domes. I mean this thing was hard as hell to pull. You had to kneel over the seat just to keep the bike from lifting off the gound!!!
Other then that, I dont know *** it could be???
Old 10-05-2004   #12
Do you have the stroker crank in your bike? I see you have it in your avatar. If you do, did you set the squish?
Old 10-05-2004   #13
guy on the couch's Avatar
Question
as well as crankcase clearance?
guy on the couch is offline   Reply With Quote
Old 10-05-2004   #14
If the spark plug is hitting the piston on the top,add the spacers from the stock plug. Because it may just be alittle off and it won't start. Or the compression is to high.
bow3022 is offline   Reply With Quote
Old 10-05-2004   #15
Well after many hours of experimenting I found the problem and as many of you said it was the plug hitting the piston. The new plug is slightly longer than the stock and therefore it was hitting. I took the spacer off the stock and placed it on the hp plug and I found it still was not long enough. Still hitting by about 2 turns out.
So I found a thick rubber oring in my shop that fit snug around the plug and that did the trick. I tightened it down and its all set. Even though I still dont have my clutch, housing or chain in I am going to start her up in about an hour to make sure it runs all good.
Thanks for all of your help!
One last question, thoughtout the testing I pulled the pull starter many many many times and since the piston was infact hitting the plug did that damage the piston?
Thanks again, I'm off to buy some gas.
Old 10-06-2004   #16
blah's Avatar
Unhappy
Originally Posted by Ride Like You Stole It
So I found a thick rubber oring in my shop that fit snug around the plug and that did the trick....
Arrghh, don't start it, go and get a proper plug, or use your old plug. The head temps go above 400 degrees the o-ring will probably melt, either the plug will be blown out taking the thread with it or it will take out the top of the piston. Go to any place that has a plug book and get the same heat range plug of your new one with the retracted style of the old one.
Man, dont let a $2 part fark your entire motor.
Old 10-06-2004   #17
Exactly!!! A plug is not gonna give you a dramatic difference in performance. I run a NGK bmp7a or a bm7a. These are $3 - $5 bucks and work well.
Old 10-06-2004   #18
yea man dont you know o rings are just gunna melt when you heat it up? get a proper plug there not going to make a difference besides temp really and the top of the piston might have a sctrach on top of it but its all filled with carbon and doesnt even matter
#1 pocket racer is offline   Reply With Quote
Old 10-07-2004   #19
Lastly... if you start using all those rings and spacers I know for sure you will not get a good seal and you will lose compression BIG time!
Old 07-23-2005   #20
Are you sure the plug isn't hitting the piston. AsNGK race plugs b8-9 egv wont fit in my Chilini engine without fouling the piston. Something to check out anyway mate.
azzanz is offline   Reply With Quote
How-To Choose the Correct Plug For Your Cag zero4 Air Cooled Pocketbike How-To's 1 11-04-2007 11:36 AM
Ngk R7282 Ride Like You Stole It Air Cooled Pocketbikes 14 03-13-2005 07:36 PM
Electic start and pull start does not work... Jovy11 Air Cooled Pocketbikes 5 01-16-2005 03:29 PM
Electric Start works but Pull Start DOES NOT PocketPride 2Stroke Midbikes 5 11-21-2004 11:25 PM
Weak spark...no start Cashmoneyspeed Air Cooled Pocketbikes 8 10-22-2004 05:31 PM
Page generated in 0.36905 seconds with 76 queries
