Old 05-28-2005   #1
ExtremeBoutch's Avatar
Ratio of compression for alcool methanol
What is the best ratio of compression for methanol a lot of thread and compani say to put 17to1 of ratio !
And in my aera I have 2 strokes performance shop he say 13 to1 of ratio for alcool ?
ExtremeBoutch is offline   Reply With Quote
Old 05-28-2005   #2
DeadLock's Avatar
Question
Hi.
I haven't tried to convert the Cag engine to methanol/ethanol, but my previous experience with 2-stroke engines running methanol is 13-18:1, depending on cooling system, nitromethane percent, etc..
I'm sure there is someone here with the proper experience that can answer more precisely.
-Thomas-
DeadLock is offline   Reply With Quote
Old 05-28-2005   #3
NITROMUNCHER's Avatar
we had a alchol injected dragster and our comp. was 17:1! you will only gain a 13% increase in hp running alchol! my opinion is it has to be 15:1 or higher!
NITROMUNCHER is offline   Reply With Quote
Old 05-28-2005   #4
I have played with alky in pocket bikes any found anything over 13 to 1 works fine and makes alot more power and runs alot cooler.
mrmuffinmanvw is offline   Reply With Quote
Old 05-28-2005   #5
thank you guys I'ill try 13to1 and 15to and I'ill running methanol pure 99.9% with out nitromethane oxident
For the carb jetting 2.2 more biger main jet and I drop of size of needle or drill 2.2 biger on the jet needle nozle ?
and couple of pictures the my monster torker twin engine
Old 05-28-2005   #6
badazztoyz.com's Avatar
haha christian you crazy ***
Old 05-28-2005   #7
djrice69's Avatar
looks heavy wow how did u seal both motors together? and what other parts did you use for the crank
djrice69 is offline   Reply With Quote
Old 05-28-2005   #8
all you have to do is connect the cranks some how!
Old 05-28-2005   #9
how did you set up the ignition for the other motor with out the flywheel...
the motors sick tho.
wasraceme is offline   Reply With Quote
Old 05-28-2005   #10
I Think ,I'm a crazy litle , for the crank I used a cilinder pipe shaft machined and woodruf keys ,
And for the spark I put two ignition coil face to face for make two spark per rotation et voila !
Old 06-09-2005   #11
Question
And for alcohol, what is the formula to calculate how much to retape the main jets
Old 06-10-2005   #12
damb that things gunna hammer hard
ok this may sound dumb i duno were to get alcohole and guessing its costs alot
would putting a few cups of vodka in with the petrol do much as it has a highish alcohole content
i thinking it may make it worse as it has other things in the vodka
but its worth a try
gobble_doc is offline   Reply With Quote
Old 06-10-2005   #13
but its worth a try
Old 06-10-2005   #14
is that a CAG? hot ****....
WranglerOn40s is offline   Reply With Quote
Compression, PSI to Ratio conversion? Kingjsa 2Stroke Midbikes 4 03-08-2005 07:26 PM
Stock Blata engine compression ratio Marto European Pocketbikes 0 02-23-2005 07:58 PM
Cag heads and compression ratio gulliver22 Air Cooled Pocketbikes 28 01-06-2005 12:22 AM
compression ratio polarice7 Air Cooled Pocketbikes 9 08-31-2004 05:33 PM
Page generated in 0.29162 seconds with 59 queries
