Old 04-26-2005   #1
Question Rims
i own a cag and the bolts on the sprocket and the disc are stripped. dose any one know where i can get a rim that wont strip out?
lil speedy is offline   Reply With Quote
Old 04-27-2005   #2
INJEN200's Avatar
rim!
you could go to ddmracing.com / adaracing.com or even ebay they should be
chaep
INJEN200 is offline   Reply With Quote
Old 04-27-2005   #3
Another suggestion is that the bolts probably go in the rim only 1/4" and you can go to the hardware store and replace the bolts with longer ones. bring one bolt with you to match up (diamiter and thread pattern) Get different lenght bolts and make sure you get enough for all brake disks/ and sprockets. Also get some thread lock. You can get all this from your Hardware store for just a couple of dollars.
jzinsser is offline   Reply With Quote
Old 04-27-2005   #4
already tried that and drilled and tapped them bigger and deeper but the aluminum just stripps out!
Old 04-27-2005   #5
insyder's Avatar
I'd say try again.
Maybe use heli-coil so you don't have to go too big? Also a heli-coil would give you steel threads when you're done.
But then you could always buy a set of wheels (with tires) on eBay for pretty cheap.
insyder is offline   Reply With Quote
Old 04-28-2005   #6
sizematters?'s Avatar
ya, these rims are sh!t. my sprocket bolts loosened up the last time we were practicing and when I went to tighten the bolts I nearly stripped them very easily. I could feel the material starting to give, it's very soft. I thread locked the crap out of them and am hoping they'll last a while. But surely I'm due for a new rear wheel too.
sizematters? is offline   Reply With Quote
"BIG PIMPEN" rims JjPredmore Air Cooled Pocketbikes 13 07-15-2005 12:38 PM
Painting Rims AtomicBiker 2-Stroke Midbike How 2's 0 02-27-2005 01:09 AM
polini rims and tires cbr600f41 Pocketbike Classifieds 0 12-31-2004 09:56 AM
swapping on some FS529/inferno rims on my cateye! BoostedBoogie 2Stroke Midbikes 44 11-01-2004 08:56 AM
Alloy rims on a GRC GP SAL European Pocketbikes 5 10-18-2004 01:30 AM
Page generated in 0.22213 seconds with 34 queries
