Originally Posted by bradsdad the carb is strait i tryed routing fuel line(5 ways)whats happening is the fuel outlet is so far to the right that if you lean to the left zero fuel goes into the line.its like sendai made the tank wrong,or they need to get larger fuel bowls on the carbs! |
Forgive me if this was posted twice. Just wanted to say that my best upgrade I've gotten so far on my Taichi was a 17.5mm Dell'Orto Carb. The kit came with a Blata manifold, Polini airfilter & shorter throttle cable. I've installed the 88 main jet and lowered the clip to the lowest postion on needle. Bike runs very strong! Also, took the liberty and corrected the lubrication holes on the piston. While having the cylinder out, cleaned up around the edges with a dremmel. Adjusted the clutch and I'm flyin'! The bike is very strong - oh, did i mention that already??? Still waiting on my Zocchi clutch upgrade, as well.
