Could be a few things, you need to play to see what works.
Firstly the blue reeds are too thin for a CAG, thay flutter at to rev's. YOu need to use the green reeds, I am using them with no problems. If after changing to the green reed or stiffer reed than the blue it is still bogging at top rev's, then you need to play with the jets,also the rich/lean setting on the needle (if you are using a standard carb). It is probably too rich or too lean, only testing different jets will tell you the answer.
I am running a Yellow Jacket copy BBK, BZM single reed (same stiffness as the Pollini green), cut out the centre brace on the reed cage, 19mm Del' orto replica carb and Jet Pro pipe. Bike flies, its awesome.
