Old 06-17-2006   #181
cagaroni's Avatar
Re: Stock pipe mod
i think the yanker was having a bad hair day...just ignore him..
Old 01-30-2007   #182
Re: Stock pipe mod
if the exspansion chamber was made longer than 2" would this release more top end?????
tusker is offline   Reply With Quote
Old 01-30-2007   #183
88Nightrider's Avatar
Re: Stock pipe mod
A wider powerband
88Nightrider is offline   Reply With Quote
Old 04-16-2007   #184
Re: Stock pipe mod
Out of curiosity, I took one of my water cooled exhaust pipes out of stock and modified the bend which bolts to the head. I noticed an amazing difference in torque and power with this set up. This pipe, of course, was installed on an air cooled. Bolting at the tail required a different clamp of course, and it looked really good. I have a lot of customers now wanting this set up, and have made 10 kits so far.
These pipes arent cheap on a retail scale, but I pick them up for about 35 Euros a piece complete. The regular exhaust for the air cooled I get for 5 to 10 euros a piece.
Minis & More is offline   Reply With Quote
Old 04-27-2007   #185
Re: Stock pipe mod
I made a new thread about the Kspeed pipes for stand up scooters that use the cateye engines, but now feel I wasted valuealble space and should have posted here.
The Kspeed seemed to help my 36cc (33cc) engine by a bunch, but it doesn't work nearly as well on a 43cc and even less on a 49cc, so I am guessing the pipe needs to be retuned for the larger engine.
Question is: Can adding 1.5"-2" of belly to the fattest part of the Kspeed pipe help improve how it works on the larger 49cc cateye engines?
The engine is fully ported to use reeds now, wider transfer ports, ported about 2mm off the top of the exhaust port, exhaust groove fixed for more compression, etc. But I can't use a decent 15mm carb and i think it is partly due to the pipe restricting the engine.
At this point, a stock 49cc head has impressed me more than all the mod work I have been doing. I even took out the rocket key hoping I was running too much advance for all the mod work, but that didn't help any. Heck, a 43cc modded head has been more impressive then my two 49's have been, stock or modded.
skywayflies is offline   Reply With Quote
Old 06-23-2007   #186
Re: Stock pipe mod
do you gain anything at all from removing just the tailpipe cover with the insulation in it or would you gain nothing but loudness. i dont want to do that unless i can actually get some power from it.
mikenacarato is offline   Reply With Quote
Old 06-23-2007   #187
nissandude's Avatar
Re: Stock pipe mod
just,2,go,def,it,real,loud----------------------------------broken,spacebar
nissandude is offline   Reply With Quote
Old 07-01-2007   #188
Re: Stock pipe mod
no you will not gain any power from removeing the silencer and it will sound extremely irritating and cuz tons of nasty oil buildup under your rear fairing :P
calebwhetzell is offline   Reply With Quote
Old 07-02-2007   #189
Re: Stock pipe mod
yup, what i figured. o well, ill just order a whole new one
Old 08-21-2007   #190
mxrayser's Avatar
Re: Stock pipe mod
OK guys, I sat in the shadows, and read every word posted about this exhaust mod(twice)! Then I not so quietly got out the chop saw and let the sparks fly. I only had about an inch of header protruding into expansion chamber (cut it off) and had none of the other garbage in there. I took off an inch of header and was going to add 2" to expansion, but found if I added 3" I could use the same mounting bracket. So I busted out the mig and arc (used both) and once again let the sparks fly. I have the twin tips and was gonna hack em and make a straight stinger, but instead I opened those babys up so its a open shot out the back. Mounted it back on for a tester, and all I have to say about it is HOLY CRAP!! Went from gutless wonder to a screamer!! major power gain off the line, gets up to speed way quicker, and stays in the meat of the power throughout the whole throttle range, major improvement! Its a little louder (not much) cause I opened the tips. but since I have a YZ250 and a YZ450F my neighbors are used to me being a little loud. So thanks to all contributed to this great thread and awesome mod. Now if you'll excuse me I got a rocket to ride!!
mxrayser is offline   Reply With Quote
Old 08-21-2007   #191
cagaroni's Avatar
Re: Stock pipe mod
glad to hear another success story with a cheap do-it-yourself mod!!
Old 10-22-2007   #192
Re: Stock pipe mod
hey all,
Ive got a question regarding the silencer end of this mod.
I get what I have to do to the header portion of the exhaust, and by removing the tube that goes into the belly.
What I need help on is; is there anything that needs to be removed from the opposite end with the silencer?
Last question: where is the "cone" at, and does it have to be removed?
Thanks to all who can help me out. Thanks
GaRsNoW is offline   Reply With Quote
Old 10-24-2007   #193
Re: Stock pipe mod
Most leave the silencer alone, but there have been a few that made theres stronger so it won't fall off. There is something in the threads about messing with the silencer but it seem like a lot of work. I believe they removed the stinger and put on a stronger one and some real fiber to silence it better. There is more to it than that, but been a while since I read the info.
Old 10-24-2007   #194
Council Member
sr20hardbody's Avatar
Re: Stock pipe mod
ok im just giving my oppinion on the stock pipe mod so heres a pic of my pipe vs the stock pipe now as you can tell even if you mod the stock pipe it'll still never be close to this.
Old 10-24-2007   #195
cagaroni's Avatar
Re: Stock pipe mod
ok looks like you took a flange & muffler off a poop pipe and welded it to a C1 header & belly??
Old 10-25-2007   #196
Council Member
Re: Stock pipe mod
nope its the pbu factory race pipe for lucky7 not the one with the tips but the race pipe they dont show pictured. it's supposed to be the same size as the ip2 or have the same volume and the stinger came like that it's like a pee shooter! i got laughed at in another site them saying my pipe was too small untill i showed them a pic of the whole thing!! then they said it was too big. but it's actually i think the same size as my banshee pipe just has smoother cones the banshee cones are steep. hmmm maybe i might try fitting it to my banshee
Old 11-04-2007   #197
team gorilla racing TGR's Avatar
Re: Stock pipe mod
bump hows about instructions on how to work the javapipe maker thingy?
http://www.mh-aerotools.de/airfoils/javapipe_en.htm
team gorilla racing TGR is offline   Reply With Quote
Old 11-27-2007   #198
Re: Stock pipe mod
i have on stock pipe and it broke should i do this? also i need some instructions
shnishigus is offline   Reply With Quote
Old 11-27-2007   #199
cagaroni's Avatar
Re: Stock pipe mod
yes.. cut out out an inch of the header and add 1-2" to the belly, clean out the crap pipe protruding at the welds into the cones and you should be good to go.. a muffler shop should have some scrap belly tubing with the same diameter in the dumpster.
Old 12-07-2007   #200
Re: Stock pipe mod
can your bike get mest up with no pipe
kauron is offline   Reply With Quote
R6 (not the Yamaha looking one) 4 Stroke Question AaronLucia 4Stroke Midbikes 27 07-14-2009 09:59 PM
Top pipe shootout Outlaw50 2Stroke Midbikes 48 02-08-2006 05:21 PM
JetPro vs. IP2 (a first hand comparison) Vol. 2.0 eldevioso Air Cooled Pocketbikes 22 04-23-2005 01:15 PM
New Jet-Pro 'High Rev' Pipe - exclusively at DDM davesmotors.com Air Cooled Pocketbikes 31 03-20-2005 04:10 PM
Page generated in 0.32361 seconds with 76 queries
