Originally Posted by eaterofdog I've been reading up on tuned pipe theory and talking to some people. Adding belly to the pipe should broaden the power band. Shortening the header should add more top end. Sounds like a winner to me. Can braze it or do I need to weld it? |
ok a few things to keep in mind with this one, with the welding, im a certified welder and I wouldn't touch it with a stick welder. to much chance for burn through. if you mig it I would set it at the lowest temp and a fairly slow speed. best bet is a tig weld..lol have fun with that one lol. another thing to keep in mind is that the 2 strokers have to have a certain amount of back pressure to run..let alone start! as long as you don't change the diameter of the pipe where it bolts up to the cylinder at, you shouldn't have any probs.. I did a similar mod to the pipe on my gp mx3 and I've already hit 56.. it gave me about a 4mph gain but a noticeable more torque off the line..have fun .
