Old 12-27-2008   #321
2 STROKER
mx3rider's Avatar
Re: Stock pipe mod
Originally Posted by SpyGuy View Post
hey, MX3, where's the picture of the pipe, dude? Inquiring minds wanna know!
oops! i deleted it... ask juan to post it...i deleted my old pm's
Old 12-28-2008   #322
Council Member
Juanitoboy93's Avatar
Re: Stock pipe mod
i deleted mine to, thats not good.
Old 01-05-2009   #323
2 STROKER
mx3rider's Avatar
Re: Stock pipe mod
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
heres a pic... the stinger is shorter and this pic doesnt really do the little guy very much justice...
Old 02-28-2009   #324
Re: Stock pipe mod
i got a question me and my friend are making a gas scooter the moter is hooked up and its a 47cc cag we have a giovonni dirt bike exhaust thats hooked up and we need to cut the cans off and i wanted to know if that would affect anything and can u bore out one of those exhausts thanks.
5horsepower is offline   Reply With Quote
Old 02-28-2009   #325
Re: Stock pipe mod
we also got down hill shocks hooked up to the back about 8 inch spring with rebound and massive forks in the front will post photos when its done
Old 02-28-2009   #326
2 STROKER
mx3rider's Avatar
Re: Stock pipe mod
please do not bring up old posts and please post them in your own thread...
thanks
Old 02-28-2009   #327
Re: Stock pipe mod
srry about that i dont really know what you meen tho im really new to the site how do i make my own threads
Old 02-28-2009   #328
2 STROKER
mx3rider's Avatar
Re: Stock pipe mod
go to the air cooled pocketbikes section, and in the top left corner, click new thread
Old 05-26-2009   #329
Thumbs up Stock pipe mod night and day difference!
I finally got around to doing the Stock Pipe Mod and I must say I am impressed. I am sure a lot has to due with luck that I found the ideal sizes to use the first try. First I made alignment marks on the belly and the header. I cut the weld at the cone where the header connects and removed the excess from inside the cone. Then I cut 1 1/2 Inches off of the header and Mig welded the header back in in alignment with the marks I made. I then cut the widest part of the belly open as straight as I could and added 2 inches of 2.75 exhaust pipe. That is how wide my stock belly is. I also cut the weld where the muffler extension comes out of the cone and made sure there was no excess in the cone. I then welded the extension back onto the cone.
I started the bike and noticed the sound difference right away. It sounds a lot crisper and it has a snappier throttle. Thats with stock jetting and air box. I have a rocket key, reeds, and clutch springs. When I took it for a ride I noticed the bottom end increase right away! It also has a wider powerband. Top end increase is 2 mph easily verified with my GPS.
I ran it against my buddies modified CAG and he has a fatboy pipe, velocity stack, and his is jetted. He has the same mods as me. I beat him off the line easy, and kept pulling on him. So a very noticeable increase in power and top speed with the sizes that I used. I have not pulled the plug yet as it runs so good! I may still need to open the airbox up and go up a size on my jet for maximum power and performance. But so far so good! Thank you whoever first tried the mod and realized its gains and sharing to the community!
SickCAGgprsr is offline   Reply With Quote
Old 06-11-2009   #330
Re: Stock pipe mod
where do you get the belly expansion metal from?
fireproofmoron is offline   Reply With Quote
Old 06-11-2009   #331
Re: Stock pipe mod night and day difference!
I got the piece of belly from my old tailpipe from my 2004 Silverado. A part of the tailpipe fits perfect, I cant describe which part but all you have to do is cut the belly in half and measure, then start hunting down a piece of pipe to fit. Could always use sheet metal, tack it up and weld the seem.
Old 06-22-2009   #332
Re: Stock pipe mod
chinese pot metal dude stuff melts with a lighter lmao
bradmack87 is offline   Reply With Quote
Old 06-22-2009   #333
Re: Stock pipe mod
ok ive kinda skimmed through the posts, im runnning a hot 47cc cag with high compression spark plug ( vw plug lmao had to rethread too lean burned the stock on in lol) with a 6 inch boost bottle help me out here, my pipes got a PHAT hole in it and i wanna CCR the sucker ( chop cut rebuild) i need some direction as far as how to construct it. my low to lowmid range is KILLER! but my mid to mid high is weak but she tops off beautifully and runs solid bearings out at the top guys.
any suggestion?
Old 06-22-2009   #334
Hooligan
SpyGuy's Avatar
Re: Stock pipe mod
Just read through this thread, bradmack87, and you'll learn how to do it. All it takes is a little patience and a lot of reading - skimming through the posts isn't going to help.
Let's see some pics of your bike, and a list of the mods you've done to it. A VW spark plug??
Old 07-12-2009   #335
Re: Stock pipe mod
Originally Posted by eaterofdog View Post
I put together this graphic showing modification of the stock cag pipe. The mod consists of three cuts and welds, removing part of the header and adding belly. The resulting pipe looks much better, how does everyone think it woud perform?
itll gain horse power but youll lose acceleration bad for turns and turns r where u want it the most.
rayray93 is offline   Reply With Quote
Old 07-12-2009   #336
Hooligan
SpyGuy's Avatar
Re: Stock pipe mod
Have you tried doing this mod, Ray?
Old 09-09-2009   #337
Outlaw
Re: Stock pipe mod
Thanks,
You guys gave me alot to to think about cause I have to Mod.
two pipes, I want all out TOP END, for my Drag Bike, with two
Big Bore 49cc HP, w/ full circle cranks!! I am turning the head
pipe, 180%, an running the exhaust under the Bike!! Some of
the Head Pipe must go, about 4 to 5" total off the Chamber &
I might come out the back of both to One Big Pipe, 2"!! EPR!
EPR is online now   Reply With Quote
R6 (not the Yamaha looking one) 4 Stroke Question AaronLucia 4Stroke Midbikes 27 07-14-2009 10:59 PM
JetPro vs. IP2 (a first hand comparison) Vol. 2.0 eldevioso Air Cooled Pocketbikes 22 04-23-2005 02:15 PM
New Jet-Pro 'High Rev' Pipe - exclusively at DDM davesmotors.com Air Cooled Pocketbikes 31 03-20-2005 05:10 PM
Page generated in 0.35949 seconds with 70 queries
