Top end problem I have an airfilter and velocity stack on my Lucky 7 type bike. Well, when the clip is on the 5th notch, the bike has great bottom and mid but sucks on top, the fourth is the same way. When it is on the fourth however, i can hold the throttle at like 3/4 and the bike accelerates how i think it should and the top end is smooth and goes quite a ways before it starts to bog down. The bike blows out a steady stream of smoke when you twist the throttle. Then I move the clip to the third and all the bike does is bog when the throttle is twisted up until half throttle, then the top end is better. Im wondering *** i should. My fingers are getting all blistered and raw from unscrewing the throttle cable from the carb and changing the clip so many times. I heard carbon fiber reeds will help WOT problems. Is this the WOT problem people refer to when they say those reeds will help?
Ryne
Reason: Because
