05-04-2008
#51 |
| Junior Member
| Re: Top speed Quote:
Originally Posted by cabridge ok, whats the best top speed you guys have got running the bike completely stock? I clocked my ff at 31mph, which im quite proud of, have any of you got any better?
Also have any of you guys done the 'lot' on you pb? things such as fuel line, petcock, air filter, carb, reeds, reed block, full circle stroker balanced cranks, huge big bore kits, plugs, exhaust,nos and sprockets? if so what are your top speeds?
Im either thinking of a different engine or doing everything to the original engine
Thanks for the replys!! | {The New Guy} to achieve top speed take the restrictor off. if you need help ask me I got 4 pb and one tops out at 80mph without the restrictor |
