Old 09-13-2004   #1
Exclamation Trouble Shooting PLEASE HELP!
Hi, I got my CKO bike early today and I have been working on it all day and can't start the **** thing up!, there is a clear hose that comes out of the carb that is open it kind of looks like it would drain it if it was flooded and there is gas leaking out of it and my bike won't start if anyone knows can you please get back as soon as possible!!!!!
daneoneill is offline   Reply With Quote
Old 09-13-2004   #2
sounds like a stuck float
It sounds like your float valve has debris in it, or the float level is incorrectly adjusted. Pull the float bowl off the carb and verify that it shuts off fuel flow when it sits level in the bowl. If it doesn't, clean the float valve, retry, and adjust as needed. Most of the cags we have been getting have plastic debris in the fuel tanks. I just pull the tank and wash it out before even trying to put fuel in when they're new.
It can be done on the bike but is a lot easier on the bench. The tube thats leaking is an overflow tube that leaks the fuel on the ground instead of into your motor if the float valve fails.
roomtemp is offline   Reply With Quote
Old 09-13-2004   #3
SilhouetteDrummer's Avatar
its also possible that when u took the carb apart u dropped the little silver "needle" that controls the overflow valve. If thats not in there the gas just keeps pouring out until u put it back in.
SilhouetteDrummer is offline   Reply With Quote
Old 09-13-2004   #4
Patrick8's Avatar
hey man i got a cag a few days ago and when i first got it i couldnt get it running!...I looked at everything assuming it was the gas tank carb w/e all that stuff..Then i checked the idle screw...screw the idle screw in all the way I got it started by screwing the idle screw all the way so the wheel can turn and get started easier. The wheel will spin like hell tho so make sure you are on the stand. Then if you get lucky and it starts run it for about 30 seconds then turn it off and adjust the idle screw enough that you can get it started again..Thats exactly how i got it running at first and now it runs great try that and see how it works
Patrick8 is offline   Reply With Quote
help me trouble shoot pleas sandbach_89 Air Cooled Pocketbikes 3 04-09-2005 11:27 PM
x1 gas trouble sabbath420 2Stroke Midbikes 3 04-09-2005 07:29 PM
Trouble starting my bike pocket rocket Air Cooled Pocketbikes 4 04-05-2005 09:28 AM
tyre trouble want_a_pollini Air Cooled Pocketbikes 4 03-29-2005 03:16 AM
Page generated in 0.21867 seconds with 27 queries
