Originally Posted by smn1 I run two gaskets and a 1.5mm aluminum spacer that shims up the cylinder almost 2mm, you will be fine. No need in cutting the gasket for the boost ports. I have single , double boost ported cylinders and never trimmed the gaskets since the gasket does not even come close to the boost ports. |
The ADA boost ported cylinder does protrude into the base so he will need to trim the gasket accordingly.
When I first installed mine I couldn't figure out why I had a fuel mist coming out of my carb in the upper rpms.
Pulled the head and noticed a dent in the gasket where the boost port was.
Trimmed the gasket away and problem solved.
