Old 11-23-2004   #1
Dave_O's Avatar
wet or dry nitrous kit?
well already having a ip2, walbro WYK carb, and boost ported bbk i want more. So i started to look at the nitrous kits. whats the difference between dry and wet kits? are they safe? im really siked about getting 1 i heard you can get up to like 25 hp thats exactly what i need lol ( very dangerous)
does any1 no where to get 1 for cheap?
recommed dry or wet kit?
any1 with nitrous pocketbike please pm on your thoughts and specs about the kit
thanks
dave
Dave_O is offline   Reply With Quote
Old 11-23-2004   #2
badazztoyz.com's Avatar
its worthless..with the money you spend you can make the bike faster and not just for a couple seconds. wet kit means it injects fuel with the nitrous and dry means it just injects nitrous and its up to you to compensate and get more fuel in to the cylinder
Old 11-23-2004   #3
Boogie-Moto's Avatar
thanks
dave
Oh my........
Boogie-Moto is offline   Reply With Quote
Old 11-24-2004   #4
Dave_O's Avatar
i still wouldnt mind having 1, i dont care if its only for a few seconds. but i got some pms and they are very expensive. i no this is way off topic but what do you need to have to change the dome compresson to stock of like 9:1 into like 10-15:1 ???
Old 11-24-2004   #5
Wicked1's Avatar
You can use a NOS Sneaky Pete setup but you'll need a small 12 v battery and a fuel pump setup to provide the extra fuel. I've seen this done at 10HP with no problems (probably just luck) but shooting a 25 hp shot into one of these engines can get quite destructive.
if you want around 25+ HP on your bike you can get a brand new KT 100 racing kart engine from yamaha for $699... it's small enough to fit in the frame with minimal mods and has more (and I mean WAY more) than enough power for any sane person to want on something this small.... not to mention you'll never have to worry about the bottle running empty.
P.S. While both ideas will work, I don't recommend either one of them.
Wicked1 is offline   Reply With Quote
Old 11-24-2004   #6
Dave_O's Avatar
i looked at ythe sneaky pete system way to expensive so i just might go with a cheaper dry nitrous kit what do you think? does it run off a battery?
Old 11-24-2004   #7
Stoneage_caddy's Avatar
ive heard of folks running a 9.6 volt battery to operate the system , apprently the solenoids can work down that low
im working on an idea useing airbrake componets from firetrucks , biggest problem has been locateing something to take the place of the treddle valve and finding older stuff that didnt use electrics , only problem is the system has a decent chance of leakage since there will be no solenoids or electricity let alone that accurate a way to devliver it over a 12v setup.....
perhaps wireing 2 9.6v rc car battery packs in series with an inline resistor to back the voltage down from 19.2 volts to 12v (would a headlamp resistor from a early 70s chrysler work here?) ....just thinking out loud again ....cuz running a small 12v motorcycle battery would make one hell of a weight penalty and the nos system would only bring you back to the speed you saw before doing this....
Stoneage_caddy is offline   Reply With Quote
Old 11-24-2004   #8
heres our setup that we did..its a dry setup
http://badazztoyz.com/images/upgrades/pbnos/
Old 11-24-2004   #9
stnt4ride7's Avatar
u can get a nitrous kit iwth little nitrous bottle the size of a small co2 tank it looks kind of cheezy but it works (kind hard 2 press if u see it)
put in ********* and then type in 7116629398 or pocket bike nitrous
stnt4ride7 is offline   Reply With Quote
Old 11-24-2004   #10
you will go through that in one squeeze..we used our 15lb bottle up in about 10 minutes lol
Old 11-24-2004   #11
Wicked1's Avatar
Hmmm... for $40 + shipping you get...
1 Co2 bicycle tire inflator ... $12
5' of 1/4" teflon hose and some hardware store fittings.... $5
10 Whipped creamer N20 bottles... about 25 cents per bottle...
Total value... about $20
Sounds like a bargain to me...
Old 11-24-2004   #12
Dave_O's Avatar
do you evan no if that would work? i rather buy 1 instead of make it myself, im pretty clueless when it comes to the nitrous stuff
Old 11-24-2004   #13
all it is is c02. n20 is basically extra oxygen in the combustion chamber so in a way its the same thing but nitrous is alot better
Old 11-24-2004   #14
Dave_O's Avatar
so the nitrous isnt really worth buying? i wanted to buy something that will raise my compression to around 13:1 istead of 9:1 but i dont no what to buy to be able to change it any ideas?
Old 11-24-2004   #15
i have a head cap that will be around 50 bux so you can chop the top off of your head and install it and basically have a headstrong kit for much less..you can adjust the compression too..maybe someone needs to be my guinea pig
Old 11-26-2004   #16
Dave_O's Avatar
has any1 tried the nos from ebay? the lil kit with the yellow handle. its like in a co2 cartridge. any 1 thats tried it give me some specs and reviews. thanks
Old 11-26-2004   #17
Wicked1's Avatar
I'm telling you, that's all they are... bicycle tire inflators... these guys are taking your money and laughing at you the whole time when you buy their kit.
Look here... www *** tri-zone *** com/catalog/TireAccess *** html
now scroll down the page and you'll see your $40 "Nitrous Sprayer" for $13... I'm sure you'll notice just how familiar the pic is.
now all you need is the teflon hose and the adapters from home depot (hint... take your tire inflator in with you and someone will help you find just the adapters you need)...
The N2O cartridges they use come out of whipped cream dispensers and cost about a quarter each (and that's ebay's prices)... the only difference here is they are filled with N2O instead of CO2.
As for the specs and reviews... I seriously doubt anyone is foolish enough to buy this kit knowing what it is. I can tell you this... those cartridges only hold 12 grams of N2O... which is less than 1/2 ounce... can you guess how long 1/2 ounce of liquid N2O lasts?
Old 11-26-2004   #18
eaterofdog's Avatar
Take your jug to a machine shop and have them machine .015–.020 in from the bottom. Then you can use base gaskets to set the compression.
Old 11-26-2004   #19
Dave_O's Avatar
what you mean by jug? whats that?
Old 11-26-2004   #20
then you alter port timing
Review of new Badazztoyz Head Kit BAT-HK Ritchey79 Air Cooled Pocketbikes 58 02-06-2006 05:08 PM
BadAzzToyz 4 Petal Read Kit Review Ritchey79 Air Cooled Pocketbikes 20 06-14-2005 10:20 AM
where can i find the sneaky pete nitrous kit? brummet24 2Stroke Midbikes 16 12-30-2004 11:41 PM
ADA Reed Kit Review snowboardgeek1 Pocketbike / Mini bike Reviews 0 12-21-2004 08:15 PM
Page generated in 0.41538 seconds with 76 queries
