good to see another aussie here!
Your bike is usually called a CAG which is short for CAGLARI. Other names are 'hf' which is short for 'half fairing'.
Do a search on mods for your bike, there are hundreds of things you can do to make it faster.
Do a search on engine identification, to see if you recieved a 40cc or 49cc engine. The only parts that wont fit from the 49cc on the 40cc engine is the conrod-gudgeon pin and piston. The 49cc gudgeon pin is 12mm where the 40cc is 10mm. Everything else is pretty much the same.
Dont get your engine confused with the midbike engine either. Look in the gallery for mid bikes and pay attention to their engines, and you will be able to tell them apart straight away. Parts for these engines dont usually work for your engine.
Hope that makes sense
